20 Most Recent LG WM2455HG XL Front Load Stackable Washing Machine with 9 Washing Programs Questions & Answers
How do you change belt?
from the back
2/23/2015 10:14:54 PM • LG WM2455HG XL... • Answered on Feb 23, 2015
My drain filter is filling up with water
Have you checked the filter for obstructions? Some objects can end up near the pump intake and reduce or block the flow. Loose change is one item that I have seen in a filter.
12/5/2014 3:21:26 AM • LG WM2455HG XL... • Answered on Dec 05, 2014
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
11/26/2014 2:05:03 AM • LG WM2455HG XL... • Answered on Nov 26, 2014
0answers
0answers
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
Lg washing machine-wt1501c
If you wish to get some details; check the site linked here. Pull up older posts........ http://electro-medical.blogspot.com/
6/12/2016 7:02:11 PM • LG WM Washing... • Answered on Jun 12, 2016
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off see if the water pump making that noise or is broken should look something like this one 26197828-pe3l0ypp1vfpknq0mkt0qwu4-3-0.jpg
5/18/2016 9:54:37 AM • LG WM Washing... • Answered on May 18, 2016
LG WM2455HG XL Front Load Stackable Washing Machine with 9 Washing Programs Logo
Popular Tags
14 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
change belt
  • Washing Machines
