20 Most Recent LG Steam Washer And Dryer Wm2650hra Dlex2650r Questions & Answers
Check filter light is on but we have cleaned everything
  1. the problem with the capacitor,,,its should be replace...
4/23/2014 8:55:07 PM • LG Steam Washer... • Answered on Apr 23, 2014
DRYER WILL NOT START
If you need to change a filter, do so. Some devices will prevent a start for safety reasons. If lint collects in the exit tube, a fire could occur.
4/2/2014 6:30:45 PM • LG Steam Washer... • Answered on Apr 02, 2014
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
Lg washing machine-wt1501c
If you wish to get some details; check the site linked here. Pull up older posts........ http://electro-medical.blogspot.com/
6/12/2016 7:02:11 PM • LG WM Washing... • Answered on Jun 12, 2016
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off see if the water pump making that noise or is broken should look something like this one 26197828-pe3l0ypp1vfpknq0mkt0qwu4-3-0.jpg
5/18/2016 9:54:37 AM • LG WM Washing... • Answered on May 18, 2016
Hi I have lg WT H550 machine when I turn on the machine the water is not stopping come into the machine what should I do water level is coming upto the top
2 possible causes the water solenoid control valve is split in the diaphragm and not stopping the water the small hose from the base of the tub to the level control pressure unit is split or disconnected or the pressure unit has failed and is not activating the water control valve
3/25/2016 7:33:57 AM • LG WM Washing... • Answered on Mar 25, 2016
My fabric softener dispenser is filled with water after a wash cycle
Take out the soap drawer and clean the fabric softner compartment. This happens when there is residues left. And it gets clogged up.
2/17/2016 6:55:13 PM • LG WM Washing... • Answered on Feb 17, 2016
2answers
Soap is not rinsing out of my clothes. It has been getting worse and worse. Even if I use a tiny bit of detergent.
The obvious question is how do you know that it is soap? What washing machine is it? The biggest problem with most washing machines is that people use too much soap to begin with. I would go to a store and get a new t-shirt or something. Run the machine with nothing in it. Then put the shirt in and run it again without adding any soap. When it is done check the shirt for soap. There could be a build up on the inside of the drum.
2/13/2016 5:42:14 AM • LG WM Washing... • Answered on Feb 13, 2016
LG Steam Washer And Dryer Wm2650hra Dlex2650r Logo
2 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
check filter light but cleaned
  • Washing Machines
