20 Most Recent
HP ProLiant ML370 G4 Server Questions & Answers
Hi , i've HP ML370
It may be that the lithium battery is dead; usually a CR2032 button battery.
Signs of CMOS Battery Failure Dom Tech Computer Blog
Go into the BIOS settings during initial power on boot up, often F10 or F2 are common. Check the date and time, if they are off, you should be able to temporarily boot by setting the date and time but you'll have to do it every time you boot. If the date and time is off, and you set the correct date and time and it still doesn't boot, you'll want to make sure it's booting to the correct drive.
When it doesn't boot, does it give you any error?
When trying to install window
The setup program does not recognise your storage controller.
HP and Dell usually supply a startup CD, that will help you configure RAID levels and partitions and start the Windows installation. If you have the supplied CD boot from it and it should work OK, if not you can download it here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=316541&prodNameId=327476&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-d7672226b6284520b9e292b9bd
Please let me know if it works, any issues send a reply :)
