FixYa.com
VisionMan Advantage 8170  Server
All Products > VisionMan > Servers
Problems with VisionMan Advantage 8170 Server?
Search inside VisionMan Advantage 8170 Server Knowledgebase
Troubleshooting and Support
Solved Problems for VisionMan Advantage 8170  Server RSS Feed Post a New Problem
Client Machine Won't Boot so I powered on...
Client Machine Won't Boot so I powered on the client machine but all I see is an incrementing counter, any suggestions?
1 Solution
HP Teaming Software
Teaming nic's on Proliant DL 585 G2 and Proliant DL380 G2 using Win2003x32 and x64connects then drops after re-boot....
1 Solution
Belkin router modem help
I need to retrieve my passkey, Ive emailed Belkin but they are taking forever to reply. Is there any way i can go about...
2 Solutions
win 2000 server driver
hi i am looking for an ATI ES 1000 driver for win 2000 server any help is appreciated.. regards
1 Solution
blutoohth
i have sky broadband are you compatable!. What devices do i need to set up my second PC to my wireless broadband?????
1 Solution
Torque Settings
hi, I am trying to figure out what I should set up as torque settings on my electrical drivers in building and...
1 Solution
tower computer
My computert hums,during startup after that it stops humming.
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorRack-Mountable 1U
ProcessorPentium D 3.2 GHz
Installed Memory1 GB (DDR2 SDRAM)
Controller TypeSATA II x 1
Processors Qty.1
ChipsetIntel E7230
Processor
Processor TypePentium D
Processor Speed3.2 GHz
Processor ManufacturerIntel
Processor UpgradabilityUpgradable
Installed Qty1
Socket TypeSocket LGA775
Max Supported Qty1
Memory
RAM TechnologyDDR2 SDRAM
Installed RAM1 GB
Maximum RAM8 GB
Supported RAM Speeds533 MHz
Hard Drive
Hard Drive Capacity400 GB
Hard Drive InterfaceSerial ATA
Networking
Data Link ProtocolEthernet · Fast Ethernet · Gigabit Ethernet
Networking Type10/100/1000 Network Adapters x 2
Technical Features
Integrated Input/Output PortsFloppy Port x 1 · External SATA port x 1
Hot Swap ComponentsHard Disk Drives
CD / DVD
Read Speed24x (CD)
CD / DVD TypeCD-ROM
Other Drives
Floppy Type3.5" 1.44 MB floppy
Other Features
Expansion SlotsPCI Express x1 x 1
Expansion Bays2 x 5.25" (External Access) · 1 x 3.5" (Internal Access)
Other FeaturesDual Channel Memory Architecture · 64bit Ready
Power SupplyCold Swap Power Supply
Power Supply Output300 Watt
Warranty
Warranty1 Year
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
