20 Most Recent Philips 42PF5521D 42 in. HD-Ready Plasma Television Questions & Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Philips... | Answered on Aug 17, 2017
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Philips... | Answered on Mar 12, 2017
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis. Contact the authorized service center for Philips to buy a genuine regulator board.
Philips... | Answered on Jul 10, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Unlike other brand sets, counting the number of blinks to Philips it different. It is not directly countable. Check the site for more details.
Philips... | Answered on Mar 28, 2014
soft waer call phillips
Philips... | Answered on Jun 08, 2013
had the same problem, did a software update and it fine now.
you can update at site for your tv.
Philips... | Answered on Mar 28, 2013
The main digital board should be suspected. Check this for more details. There are so many reasons for this fault. The flashing of LED at its front panel denotes this. Count the number of flashes. You can get more details form the site linked above.
Philips... | Answered on Dec 31, 2012
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Philips... | Answered on Jul 27, 2012
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Philips... | Answered on Apr 01, 2012
I had this problem and had to get a new digital board installed - costs c€150-200 euro.
Philips... | Answered on Nov 12, 2011
Usually when something like this happens, with any tv set. it is the tv stopping its self from turning on to prevent more damage being done to it internally. You are more then likely to need a repair on this. Check out prices of local repairers in your area and see what sort of quotes you can get. but to be honest if it is a problem with the screen and not the PSU then it could get pricey
Hope that help
Philips... | Answered on Jul 19, 2011
This is a plasma screen T.V. and doesn't use a lamp. You are probably correct in thinking it's the T-Con board. This board is sometimes a pain to get it. When you get to the board, look up the board number on the side on e-bay or other internet resources for the lowest price if you're comfortable changing it yourself.
Philips... | Answered on Jun 20, 2011
Check power board . Replace any capacitors that have domed tops.
Philips... | Answered on Jun 08, 2011
Hallo! You might have a power trouble. Open the rear cover and take a look over the power board- that's the board where goes the alimentation cord. Look if there are not inflated the electrolytic capacitors, if yes, you must change them with the same type. Be careful with the polarity of the capacitors- you must solder them the same way as the old ones were.
Philips... | Answered on May 13, 2011
Here's the main support page for your unit in case you need the User manual or other documentation:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=42PF7321D/37
You may need ADOBE READER installed on your computer to read the USER MANUAL - PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Assuming the warranty is expired, you should have no problem disassembling the unit enough to access the speakers with just a phillips screwdriver.
Normally you just lay the unit screen side down on a soft flat surface like a bed. Just make sure nothing will gouge or scratch the screen.
Then just remove screws for the stand and pull it off (see page 2 of the Online Owners Manual).
After that you can remove all the screws from the back panel and remove the plastic enclosure.
You should be able to access the speakers from there.
Here is a link to some spares from EBay:
http://shop.ebay.com/i.html?_nkw=Philips+plasma+speakers&_sacat=0&_odkw=42PF7321D%2F37&_osacat=0&_trksid=p3286.c0.m270.l1313
http://shop.ebay.com/i.html?_nkw=Phillips+tv+speakers&_sacat=0&_odkw=Phillips+speakers&_osacat=0&_trksid=p3286.c0.m270.l1313
I didn't actually see any speakers for your exact model, but the online selection changes constantly so you may just have to get lucky and spot one that will fit.
The other option is to just go into your MENU and turn the speakers off. Then just use the rear outputs to feed into a home stereo / home theatre system for your audio.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Philips... | Answered on Feb 25, 2011
Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
Popular Tags
56 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
flashing green light no picture phillips
  • Televison & Video
