FixYa.com
Topower 400-Watt Power Supply
All Products > Topower > System Power Supplies
Problems with Topower 400-Watt Power Supply?
Search inside Topower 400-Watt Power Supply Knowledgebase
Troubleshooting and Support
Solved Problems for Topower 400-Watt Power Supply RSS Feed Post a New Problem
screaming fan
hi, hope u can help. i have an hp compaq d350 with a screaming fan. it sounds like some sort of aircraft taking off when...
2 Solutions
150 W ATX Power Supply HP-150SS
how can start this whitout pc ? This is not a normal psu , is a DELL.
1 Solution
idle problems
I have a yamaha 650 V-Star Custom. I am having trouble setting my idle above 1000rpms. The bike cuts off. The only...
2 Solutions
NEC Versa M320 cmos problem!
I have an NEC Versa M320 Laptop which i am trying to clear the cmos battery on or try and change the cmos battery on!...
2 Solutions
gateway desktop troubleshooting
something happened to my e3200 desktop. when i made the power on nothing happened but the online connection light is on....
1 Solution
ac power adapter
Hi. I just bought an Illumbeam 20-LED pivot lantern made by Innovage. It can run on 3 D batteries or an adapter. only...
2 Solutions
HP Pavilion a705w power supply
Power supply fan doesn't come on so i assume the power supply is bad. It would boot to Windows start up but never open...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
CompatibilityATX 12V
Wattage400 Watt
Number of FansDual Fan
Power Properties
AC Input115V @ 12A, 230V @ 6A
DC Output+3.3V @ 26A, +5V @ 40A, +5VSB @ 2.5A, +12V @ 17A, -5V @ 0.8A, -12V @ 1A
Dimensions
Depth5.7 in.
Height3.3 in.
Width5.9 in.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
