20 Most Recent
Chi Mei Corporation A190A2 LCD Monitor Questions & Answers
Turn on monitor,comes on 3
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
4/25/2011 1:31:43 AM •
Chi Mei...
Answered
on Apr 25, 2011
I already change the
The capacitor had
bursted and so it is important to clean off all the
electrolytes on the power board. Also there can be faulty components on the power supply that would have failed along.
It is
important to clean or use a soldering iron on the components and if you hear a steaming noise then there is liquid at the base of all components which must be cleaned , even removing and
re-soldering the components.
Please check the link for
SMPS tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
3/30/2011 6:39:06 AM •
Chi Mei...
Answered
on Mar 30, 2011
Off automatically while work
- First try to check the settings of the monitor make sure it is not set to automatically power off while not using it.
- Secondly make sure that the cable for the monitor are properly connected and always check the voltage regulator if the fuse is still in good shape.
If you have questions feel free to reply to this solution. Thank you. I’m happy to assist further over the phone at
https://www.6ya.com/expert/ramy_d9e7ebea3891f482
2/11/2011 1:05:25 AM •
Chi Mei...
Answered
on Feb 11, 2011
