20 Most Recent
Samsung SCX-4521 All-In-One Laser Printer Questions & Answers
How to reset Samsung all in one multi photocopy ?
Please follow the steps as provided below:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Thanks,
E-ware
our Samsung SCX-4521F laszer printer
Hello,it's
either the lamp in the fuser is burnt, the thermistor (heat sensor) on
the fuser is burnt, or the low voltage power supply is not providing
enough voltage to the fuser lamp. Your safest bet is to replace the
fuser.
i will advice you replace the fuser to be on a safer side.
thanks for using fixya,
take care.
How to reset the scx 4521
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH. www.nakshatraworld.com
Erreur laser
If your device is displaying 'Laser error' then you most likely have a faulty Laser Scanner unit
This will need a service technician to repair / replace it.
Prints blank in black
your printer high voltage power supply board voltage is not correct .so please check the hups board
