20 Most Recent Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
You can call Viking and they will know for sure.I would think,as it is of comercial quality,that there may be a wire or more on the back.Most likely to connect to an ANSUL system,a type of fire suppression.It could also be for a vent hood or some attachment like a rotisserie.You can call them at 1-888-VIKING1 (1-888-845-4641).
Viking 48" 6... | Answered on May 12, 2011
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Viking 48" 6... | Answered on Oct 20, 2010
no, its 110V if you are thinking of buying the one you listed...its gas and a great range, its just out of my league with the price they ask for them.
Viking 48" 6... | Answered on Oct 15, 2010
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Viking 48" 6... | Answered on Sep 15, 2010
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Viking 48" 6... | Answered on Jul 03, 2010
You can try allvikingparts.com, they ship to Canada for about 20$. Total cost was part price (in my case an ignitor for 65$) plus shipping (20$) plus duty (14$). Way cheaper than if I had ordered the part locally. Arrived within a week or so to my door. Telephone 888 988-4546.
A tech who came to my house also gave me three other numbers - although I never tried any of them as I found the one above online ... these may be located in Calgary - not sure
1 800 914-4799
1 800 467-2665
1 800 451-4133
Viking 48" 6... | Answered on May 22, 2010
they may recommend but you are still bound by the building code in your locality. what distance does your building code require. you may be able to alter your setup to meet the code.
Viking 48" 6... | Answered on Nov 29, 2009
you have a bad ignition switch some where
un plug it ( the range) and uses matches
its alot cheaper and much less the headache
Viking 48" 6... | Answered on Oct 03, 2009
spark ignition system not working, may need to replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Viking 48" 6... | Answered on Aug 01, 2009
It sounds like the Thermostat is defective.
Element can be removed from the front of the unit, it does not need to be pulled
Viking 48" 6... | Answered on Mar 11, 2009
You will need a neutral, ground and 2 wires carrying 120V each
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Viking 48" 6... | Answered on Mar 01, 2009
Viking 48" 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel (Electric and Gas) Kitchen Range Logo
30 questions posted
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Steve Allison
Steve Allison
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Kitchen Ranges
Most Popular Question
cleaning manual 6 burner griddle viking
  • Kitchen Ranges
