FixYa.com
Garland C1836-7 Gas Kitchen Range
All Products > Garland > Kitchen Ranges
Problems with Garland C1836-7 Gas Kitchen Range?
Search inside Garland C1836-7 Gas Kitchen Range Knowledgebase
Troubleshooting and Support
Solved Problems for Garland C1836-7 Gas Kitchen Range RSS Feed Post a New Problem
My surface element has to be...
My surface element has to be "jiggled" or pushed in to make it work....what may be wrong ?
1 Solution
How do I clean my tempered glass surfaces?
1 Solution
How do I clean my control panel on my...
How do I clean my control panel on my range or oven?
1 Solution
Surface element doesn't work
I have an electric kitchen range. What do I do if the surface element doesn't work?
1 Solution
oven and clock inop
on the display there is one red dot that is all. the clock and oven is inop. thank you for your help in advance.Roy...
1 Solution
oven not working properly
Everthing about the range seems to be working properly, except the oven. When turned on, the burners do not produce a...
1 Solution
Oven does not light
When I turn on the oven, the display goes to PrE (preheat mode) but the oven does not heat up. The ceramic igniters are...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGas
Element TypeBurner
Garland Contact Information
Email supportinfo@garland-group.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
