20 Most Recent Fujitsu Siemens (FPCFDD16AP) (FPCFDD16AP) External Floppy Drive Questions & Answers
Keyboard unlock fn key lock
I have Fujitsu laptop some of the keys are lock how do I unlock them please
9/2/2022 8:51:09 PM • Fujitsu Siemens... • Answered on Sep 02, 2022
3answers
Beep code 1-3-3-1
It's the condensator near RAM. Exchange - it works.300 µF / 6,3 V
1/13/2019 5:34:28 PM • Fujitsu Siemens... • Answered on Jan 13, 2019
Atheros AR5007EG can't connect via WPA2 to WLAN on Windows XP
WPA2 is considered insecure and hacked years ago. You might try WPA, or get a different Adapter.
9/9/2018 6:04:58 PM • Fujitsu Siemens... • Answered on Sep 09, 2018
0answers
0answers
0answers
0answers
Hi I have a Fujitsu Siemens
Whenever you can't connect to a network it is rarely the computer that is at fault, especially if it has been working. Step 1, however, is to turn off your modem, router, and computer for 10 to 30 seconds, then turn on the modem and router (often the same unit), then the computer. If the computer is connected to an Ethernet cable, make sure you see lights on both ends of the cable, on the router and on the computer, if not, unplug and re-seat the plugs. Step 2, If step 1 did not resolve the problem, bring up your command line on the computer. In Windows, click start and type cmd then hit the enter key or Win+R, type cmd and hit the enter key... this will bring up a command line tool. In Linux, find the terminal app. Step 3, in the command line tool, type: ipconfig (ifconfig if you are using an Apple or Linux product) and hit the enter key. You will be presented with a list of items, look for your IPV4 IP Address. Your IP address should look something like 192.168.0.048. If the first number is 169 you are not connected to any network. Look for a default gateway and write down that IP address (usually 192.168.0.1, but could be something like 10.10.0.1) Step 4, type the command ping 192.168.0.1 (use your gateway address). If you get replies back from that, you are able to talk to your router. Step 5, type the command ping google.com. If you get no replies back, your internet service provider is most likely down, and you should call them. It could also be that your DNS server is not properly configured in your network settings, but if your computer WAS working, it should still be OK. Step 6, If none of the above solves your problem surfing the web with a browser, then your browser may have been hijacked, you will want to run a couple of good anti-malware utilities to find out. I use two to solve most problems: HitManPro (www.hitman.com) and MalwareBytes (malwarebytes.org)
10/25/2017 6:56:07 PM • Fujitsu Siemens... • Answered on Oct 25, 2017
Usually you can hook up a monitor the the VGA out on a laptop and then find the info you need. Hook it up before you boot.
10/2/2017 10:09:54 PM • Fujitsu Siemens... • Answered on Oct 02, 2017
Blue screen death
All your data is probably OK. The best way to access it is to remove the disk and put it into another computer. You should then be able to find the data on the disk, although it will have a different drive letter. Next time make sure your keep back-ups of all your important data.
8/20/2017 7:35:32 AM • Fujitsu Siemens... • Answered on Aug 20, 2017
Can send email from my yahoo,but when i try to
It is probably easiest to talk to your new provider about the problem. They should help you with the settings. Just be aware of your operating system details and describe the problem indicating your system is defaulting to the old provider's mail server and that of course is not working for you. That said, note the hotliked table below: http://www.serversmtp.com/en/what-is-my-smtp Notice in the table you have a smtp setting for O2. I rather suspect that is the setting you are missing. Just as an aside, here is a bit of info about setting up Outlook. https://www.groovypost.com/howto/outlook-com-settings-pop3-smtp-imap/ And lower in the table list first mentioned, you have a smtp setting for yahoo. That may come in handy. But I encourage you to contact your provider.
7/31/2017 6:19:31 AM • Fujitsu Siemens... • Answered on Jul 31, 2017
What is the code of zd920 on the back of
hi hope this helps :-Fujitsu Siemens Computers Fujitsu Siemens Basic Line 43B1-M Computer Monitor also here is a link for the online manual http://office.manualsonline.com/manuals/mfg/fujitsu_siemens_computers/fujitsu_siemens_basic_line_43b1_s26361k883v150.html?idProd=63836
7/20/2017 3:39:19 PM • Fujitsu Siemens... • Answered on Jul 20, 2017
Fujitsu Siemens (FPCFDD16AP) (FPCFDD16AP) External Floppy Drive Logo
1 questions posted
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Siemens Computers & Internet
Most Popular Question
atheros ar5007eg connect via wpa2 wlan
  • Computers & Internet
