How do I remove the existing control panel to replace it with a new one? I have already taken off...
(More)
How do I remove the existing control panel to replace it with a new one? I have already taken off the two side trim strips but cannot figure out what else is holding the panel in place. Do I need to remove the oven from the wall? Any assistance you can give will be greately appreciated.
Nothing works on our whirlpool RBD306PDB12 Double oven. You can touch the start pad and all it does...
(More)
Nothing works on our whirlpool RBD306PDB12 Double oven. You can touch the start pad and all it does is give 3 beeps. What could be the problem?
I have a whirlpool double oven Model #RBD275PDS14, the display is completely off and the oven will...
(More)
I have a whirlpool double oven Model #RBD275PDS14, the display is completely off and the oven will not operate. I am told the P/N 8302319 is the problem could this be true
display is off too. beeps every once in awhile. Cannot set time, bake, or broil because when I press start? the entire display disappears. PF and F2 appear EVERY SO OFTEN. TRIED RESETTING THE COMPUTER BY TURNING OFF THE CIRCUIT BREAKER BUT NOTHING HAPPENS TO HELP. DISPLAY IS BLANK NOW.
The convection is off. The Oven is started in traditional baking mode. It starts with a loud humm...
(More)
The convection is off. The Oven is started in traditional baking mode. It starts with a loud humm almost to the volume level of what a microwave makes when running, but it is a different sound because this is not a microwave oven. It is convection on top with traditional oven on bottom. The sound gets a little more quiet once it heats up to setpoint, but the vibration and sound never goes away. The unit is about 3 years old, and has been doing this for several years now. It is getting louder with time.
Whirlpoool Oven 465 - touch pad will not go belwo 350 degrees...I bake a lot and I need it to be...
(More)
Whirlpoool Oven 465 - touch pad will not go belwo 350 degrees...I bake a lot and I need it to be less degress sometimes - help!
I set my oven at 350 degrees. I had put a pan of garbanzo beans in the oven to bake for 40 minutes...
(More)
I set my oven at 350 degrees. I had put a pan of garbanzo beans in the oven to bake for 40 minutes after the first 10 minutes I saw an error on the panel, did not write it down before pushing the off button. Tried opening the oven and it had locked. Smoke was coming out of the oven when we tried to open the door. We turned off the circut breaker and turned it back on. It then allowed me to turn the light on and when I did there was fire in there. Only thing I can think of it over heated and shut off and locked up. Fire department had to come out break open the oven. Needless to say we need a new oven. I don't think I will get the same kind. Ours was 7 years old.
The lower oven door won't close all the way. Is there a simple fix for this without pulling the...
(More)
The lower oven door won't close all the way. Is there a simple fix for this without pulling the whole oven out of the wall and taking off the panels to change the hinge stops?
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING: 1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING 2. TURN THE...
written by NATALIENATAL
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control...
written by babrown
Before you bake something, your oven needs to be heated to the proper temperature. While it takes only a few seconds to turn on your oven, it can take...
by wikihow
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
