FixYa.com
Whirlpool RBD245PDS Electric Double Oven
All Products > Whirlpool > Ovens
Problems with Whirlpool RBD245PDS Electric Double Oven?
Troubleshooting and Support
Solved Problems for Whirlpool RBD245PDS Electric Double Oven RSS Feed Post a New Problem
OVEN BLACK-OUT!
This oven has stopped working. The display is blank. When you press a button in beeps, but the oven does not work. To...
4 Solutions
The upper oven door is
The upper oven door is locked shut and will not release. All lights are off on the display panel and the oven does not...
1 Solution
Control Panel
I am trying to replace the control panel. Does anyone know how to remove the face plate on this oven?
1 Solution
gas oven won't heat
just that. you turn it on, it smells funny, like partially burned natural gas, and doesn't heat to cooking temps. it got...
1 Solution
Hobart Universal Cooking Range CSD-UC
We have the above cooking range and it has an error 10 on it, can you help with this matter?
1 Solution
ER1 F2 error on Whirlpool Super Capacity...
Hi, our Whirlpool Super Capacity 465 model RF386PXE after it reaches desired tempature will often begin locking and...
2 Solutions
Oven won't stay on and give an F error...
When I turn on the oven it won't stay on. The cpu timer will beep and give a F3 error message. I already replaced the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Whirlpool RBD245PDS Electric Double Oven RSS Feed Post a New Problem
Please advise .....
How did you fix your oven? I have the same error code (EO F2). Do you actually have to pull the ovens out or does the...
Post a Solution
i was wondering how i
i was wondering how i use the self clean mode thing
Post a Solution
Fuse
Hi, I have the same problem on a different model number. Do you have a picture of the control panel thermal fuse part...
Post a Solution
double wall oven showing a
double wall oven showing a E2-F3 and E0-F3 CODE
Post a Solution
what is the INTERNAL measurements
what is the INTERNAL measurements IN INCHES for your double electric oven model RDB245PRB NEED LENGTH WIDTH AND...
Post a Solution
Control panel does not light
Turned the breaker off for 15 minutes. After turning back on, clock came on for about ten seconds and went right back...
Post a Solution
How do you replace the Thermal Fuse?
My display is totally blank but there is power to the oven. So I assume from your previous solutions on FixYa that this...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Self CleaningWith Self Cleaning
Oven TypeDouble
Energy SourceElectric
Other Features
Capacity3.3 cu/ ft
Secondary Oven Capacity3.3
Number of Racks3
Dimensions
Overall Depth23.88 in.
Overall Height50.94 in.
Overall Width23.75 in.
Warranty
Warranty1 Year
Whirlpool Contact Information
Main support number1-800-253-1301
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
