20 Most Recent
Frigidaire Fridgidaire Mini Split System 18 Seer/12,000btu Questions & Answers
Why is my ice machine in my fridge not working at all
THE WATER LINE MAY BE BLOCKED. IF IT IS RUN BY A COMPUTER CHIP THAT CHIP MAY HAVE STOPED WORKING & NEEDS REPLACED. THERE COULD BE A BENT IN THE HOSE SOME PLACE. THE MECHINIZUM INSIDE ICE MAKER COULD BE BROKEN OR NOT MAKING CONTACT. IT MAY BE THAT IT'S JUST GOTTEN TO OLD TO WORK & NEEDS REPALCED.
Window ac/heater freezes up when using the heater?
This is likely due to a lack of airflow. Make sure that the air filter is clean and that there are no obstructions blocking the air intake or exhaust vents. If this does not resolve the issue, you may need to have a technician come out and inspect the unit for any other potential issues.
Can't change temperature on AC
thats normal its showing ambient when you lower it the number will change to the setting and then will go back to show what the ambient temp as the room gets cooler the temp number will go down and shut off at set temp
