FixYa.com
Santa Fe Dehumidifier
All Products > Santa Fe > Dehumidifiers
Problems with Santa Fe Dehumidifier?
Search inside Santa Fe Dehumidifier Knowledgebase
Troubleshooting and Support
Solved Problems for Santa Fe Dehumidifier RSS Feed Post a New Problem
Why does my dehumidifier ice up?
1 Solution
How often should I empty the water...
How often should I empty the water reservoir?
1 Solution
Is it normal for my unit to run...
Is it normal for my unit to run continuously?
1 Solution
Noisy dehumidifier
My dehumidifier is very noisy. Is that normal?
1 Solution
Unusual smell
My dehumidifier Gives Off an Odor. How can I stop that from happening?
1 Solution
Damby ddr451
I just bought my dehumidifier. It says that when you first plug it in the green power light flashes till you hit the...
1 Solution
Bogus 'Full' warning
This device has worked well for a couple of years with an attached hose running to a basement sump. It's never been...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Sq. Ft. Coverage3750 Sq. Ft.
Pints per 24 Hrs135 Pints
Humidity ControlHumidistat
Controls TypeAnalog
Technical Features
Energy Star RatedYes
Dimensions
Depth20.75 in.
Height18.65 in.
Width33 in.
Weight99 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
