Home
My Products
Sign In
All Products
Santa Fe
Dehumidifiers
Problems with Santa Fe Dehumidifier?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
Should I run my dehumidifier all year...
Should I run my dehumidifier all year long?
1 Solution
How often should I empty the water...
How often should I empty the water reservoir?
1 Solution
How do I know what setting to use?
1 Solution
Dehumidifier Doesn't Deumidify Well
It's just not dehumdifying properly and I'm at a loss.
1 Solution
Dehumidifier frosts up
There's frosting on top of the dehumidifier. How do I fix that?
1 Solution
Unusual smell
My dehumidifier Gives Off an Odor. How can I stop that from happening?
1 Solution
does not turn on
I turned off the machine, emptied out the water, put the tank back in and turned the machine on. Nothing happened...
1 Solution
View All
Tips & Tricks
Post a New Tip
How to your prevent your santa fe...
- Written by
JefferyK
WikiManual
Post a New Chapter
Be the first to Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Sq. Ft. Coverage
2200 Sq. Ft.
Humidity Control
Humidistat
Controls Type
Analog
Technical Features
Drain Hose
Connectable
Energy Star Rated
Yes
Dimensions
Depth
33 in.
Height
19 in.
Width
14.5 in.
Weight
71 lb.
Warranty
Warranty
1 Year
Sponsored Links
wagdo
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
SANTA FE
Register as STAFF
New Products
Powered by
Repair Service
Find Dehumidifier Repairman Near You:
Advertise Here
powered
by
Get this Widget
