FixYa.com
Santa Fe Advance 90 Dehumidifier
All Products > Santa Fe > Dehumidifiers
Problems with Santa Fe Advance 90 Dehumidifier?
Search inside Santa Fe Advance 90 Dehumidifier Knowledgebase
Troubleshooting and Support
Solved Problems for Santa Fe Advance 90 Dehumidifier RSS Feed Post a New Problem
Should I run my dehumidifier all year...
Should I run my dehumidifier all year long?
1 Solution
Is it normal for my unit to run...
Is it normal for my unit to run continuously?
1 Solution
Noisy dehumidifier
My dehumidifier is very noisy. Is that normal?
1 Solution
does not turn on
I turned off the machine, emptied out the water, put the tank back in and turned the machine on. Nothing happened...
1 Solution
wheelchair through floor lift
where do i obtain instructions on how to install a wheelchair through-floor lift,already done the aperture in celling...
1 Solution
Dehumidifier
The fan runs, but no water collects in the reservoir. I have checked the filter and reduced the humidity percentage....
1 Solution
Delonghi dehumidifer
This unit has started to ice up. Is it time to replace it or can it be fixed?
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Pints per 24 Hrs90 Pints
Humidity ControlManual
Controls TypeAnalog
Technical Features
Drain HoseAttached
Energy Star RatedYes
Dimensions
Depth33 in.
Height19 in.
Width14.5 in.
Weight71 lb.
Warranty
Warranty2 Years
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
