20 Most Recent
Icom Tait Tm-8200 Programming Aplication Software Cd Questions & Answers
Why is my icom ic-718 hf radio stuck in tx mode?
It can be a few things but first try resetting your CPU, while your transceiver is off, hold down the UP & DOWN buttons simultaneously then turn the transceiver back on, now it should be reset to the factory default settings
11/29/2023 11:26:24 PM •
Icom Radio...
Answered
on Nov 29, 2023
ICOM A210 aircraft radio transmits but is not recieving
The RX light should light up when receiving a signal. It may be your squelch setting is too high. Push the VOL knob until it enters the squelch setting, then set the squelch so it just cancels noise. If still not working you could have a wire broken in connector from headset that plugs into the radio.
Remote key pad for IC-7610, I press a button and just get a beep like no memory is loaded, but memories on screen work.
If you're hearing a beep when pressing a button on the remote keypad for your IC-7610, it's possible that the keypad is not programmed correctly or is not communicating with the radio properly. Here are a few troubleshooting steps you can try:
- Check the connection: Make sure the remote keypad is securely connected to the radio's remote jack using the supplied cable.
- Check the settings: Make sure the remote keypad settings on the radio are configured correctly. Press the MENU button on the radio, select "Set" and then "Remote Operation." Check that the "Remote Type" setting is set to "IC-7610" and that the "Remote Address" matches the keypad's address.
- Check the keypad programming: Make sure the buttons on the keypad are programmed with the correct commands. You can check this by pressing the MENU button on the radio, selecting "Set" and then "Function Keys." The functions assigned to each key should be displayed on the screen. If they are not, you can program them by pressing and holding the F key on the keypad and then pressing the button you want to assign a function to.
- Reset the radio and keypad: Try resetting the radio and keypad to their factory settings. You can do this by pressing and holding the POWER button on the radio until it turns off, and then pressing and holding the FUNC button and the ENT button on the keypad while turning the radio back on.
If none of these steps work, it's possible that there is a hardware issue with either the radio or the keypad. You may want to contact the manufacturer's customer support for further assistance.
Model 718. Why is CW mode kaput?
There are a few possible reasons why your radio might not be transmitting in CW mode. One possibility is that the keyer chip has gone bad. Another possibility is that there is a problem with the power supply. If you have a multimeter, you can check the voltages to see if they are within specification. Finally, it's also possible that there is something wrong with the antenna connection. Make sure that everything is securely connected and that there are no loose wires. I hope this helps!
How to fix or troubleshoot icom v68 with low volume?
Try using an external speaker and see if you have the correct volume level. Radio speakers fail often, especially when used at high volume. The simple fix is to replace the speaker. It is seldom for the audio amplifier to fail this way. Usually they work or they don't.
