20 Most Recent Hoover F7458-900 Upright Vacuum Questions & Answers
burned up motor. Take it to your local vac shop for a quote on repair or replacement.
Hoover F7458-900... | Answered on Jun 12, 2017
www.espares.com Thats where you will get your parts.
Hoover F7458-900... | Answered on Dec 27, 2009
The pointed valve that is in the tank may need replacing. The two valves are a set. I just ordered some from www.usavacuum.com
Hoover F7458-900... | Answered on Sep 06, 2009
Hello there,
Are you certain on the model number of your Hoover vacuum, I can't seem to find any reference to that anywhere online.
Either way, I am familiar with these steam cleaning type vacuums. The electrical control for the spray portion is located in the actual base of the unit, below where the water / solution sits. It is actually very complicated to take this portion apart and attempt a manual repair without extensive knowledge of the vacuum system. It is very easy to damage the unit further without thorough knowledge of the electrical systems in the vacuum. You would be much better off taking it to a local service center. On Monday I would give Hoover a call at 1-800-944-9200 and they can direct you to the nearest location that is certified to work on Hoover vacuums.
Hoover F7458-900... | Answered on Jun 27, 2009
A belt melting usually means it is stretched out and so loose it is slipping on the brushroll or something is restricting the brushroll from turning freely.
Hoover Vacuums | Answered on Apr 19, 2018
try cleaning possible debris in linkage
Hoover Vacuums | Answered on Apr 14, 2018
possible heater element shorted
twist the container anti clock wise 1/4 turn and it comes off
arrow directions on body of the unit
Clue here
following problems under warranty , I took mine in for repairs and found that the design fault did not allow for the section from the head to the canister blocking up which resulted in an over heated motor
The fix is a redesigned head that has a removable section that allows access up the suction tube to the canister for cleaning of the small tube section
indications are --doesn't appear to have enough suction
Talk with your hoover service agent and consider replacing the old head with the new model
Hoover Vacuums | Answered on Apr 13, 2018
Your filter is probably restricted and is not allowing enough air to pass through. Filters should be cleaned frequently (some after each use) and replaced about once a year for most models.
Hoover Vacuums | Answered on Apr 09, 2018
The motor protection sensor can be triggered by an obstruction or something restricting the brush roll from turning freely. Make sure it can spin freely. If there is hair, dust or debris in the end caps of the brushroll it can restrict it from turning freely.
Hoover Vacuums | Answered on Apr 08, 2018
Your Vacuum is from the Elite series, without your model number I can't be specific but to change the belt on most of them you need to remove the top cover by releasing two tabs underneath to allow the cover to flex so you can remove it. Stick a screwdriver in to move the cover out enough to be released. Remove the belt from the motor shaft, remove and clean or replace the brushroll. Put the new belt around the brush roll and insert it back into the vacuum. You need to stretch the belt enough to get it over the motor shaft. It’s difficult with a new belt because it will be so tight. I insert a big screwdriver through the belt and then put the end of the screwdriver on the motor shaft as a fulcrum to use screwdriver to stretch the belt far enough to go on the motor sxhaft.
Hoover Vacuums | Answered on Apr 07, 2018
Ok, if it has stopped sucking then something is blocking the intake. take the hose off and check it for any blockages, i am pretty sure thats all it could be
Hoover Vacuums | Answered on Apr 04, 2018
Hoover F7458-900 Upright Vacuum Logo
Popular Tags
11 questions posted
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
buzzing noise when machine turned
  • Vacuums
