20 Most Recent
GE Hand Held Cb 40 Channel Model 3-5980a Transceiver Questions & Answers
Ge cb radio
Possibly a bad volume/on/off volume potentiometer. Try using canned air around the volume/on/off knob to remove any debris down along the shaft. If this does not help, your unit may need repair. Do not use any chemicals, cleaners or solvents on the shaft, only use air.
Clean your internal battery contacts on the batteries and the radio with a pencil eraser to assure good connection. If you are using rechargeable batteries, try charging the batteries again.
Best regards.
Walkie talkie frequency
This radio operates in the GMRS/FRS radio service area. 462.5625 to. 462.7250 MHz. The GMRS frequencies technically need an FCC license. Most people don't have a license.
3/7/2015 6:03:41 AM •
GE Radio...
Answered
on Mar 07, 2015
Headset not working corectly
If the headset works normally, then check the headphone settings on that internet software, make sure that correct audio device is selected in the settings.
12/9/2013 6:20:22 AM •
GE Radio...
Answered
on Dec 09, 2013
Ge plsh05 radio manual
Hi Howard,Is there any noise or voice coming from the speaker before you try to transmit?If so, you are trying to talk at the same time the channel is already in use, be it voice or someone holding down their PTT button without talking just to be a nuisance.If this is correct, then nothing wrong with your radio, and nothing can be done about the button pusher blocking the channel.Sorry if I have been of no help here, some things are beyond my scope.Cheers,Peter
3/11/2013 11:15:59 AM •
GE Radio...
Answered
on Mar 11, 2013
Eight Channel Units
GE 2-way radios8 Channel units, got that much, but you left out the most important bits, it's called information, we thrive on more info, the more the better, it saves us from having to guess what you require.Cheers,Peter
3/11/2013 8:26:44 AM •
GE Radio...
Answered
on Mar 11, 2013
