20 Most Recent
Thetford RV Refrigerator - N300 Model - Type - 3-Way Questions & Answers
Smelling burnt gasses
Make sure your roof vent is not clogged immediately. If you are in a full service park, you should be running on electricity not propane. You don't describe the gasses you are smelling, if it is ammonia, your frig is probably done for.
Ammonia is the primary ingredient in the cooling process. What happens is the ammonia is boiled and then sprayed throug an orfice. The spraying creates the cooling (heat removing) effect. If you are smelling ammonia, your boiler has developed a leak.
You can purchase replacement units to install in your present frig. Some people have success with this. My experience was not so good. I spent about $225.00 plus shipping for a rebuilt unit (with a 'core' charge). I did the work myself. I got about a year out of the rebuilt unit before I simply replaced the frig with a new replacement 3 way Norcold. My new Norcold was much improved over the earlier model and included a ice maker! It was expensive, however, at more than $1300.00. Find sources for replacement cooling units for your "Thetford" refrig at FixYa.com advertisers or through your RV dealer or in the back of travel trailer magazines.
I hope this is NOT your trouble and I hope you find resolution. Thank you for your interest in FixYa.com and please come again.
Model 12110 IM Norcold-not cooling
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician.
If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Norcold fridge does not stay cold.we turn it to lp
Quit playing with it ... absorption refrigs work slow ... and do not recover well ... If yours has a thermostat ... set it a little lower ... check it in the morning ... use a thermometer inside. Keep track of the temps.
Putting warm food in the frig will result in a big slowdown in recovery.
Thanks frr using FixYa.com
Thetford N90 EL.L built-in has stopped
If it won't cool on all 3 power sources the cooling unit is probably faulty. Contact Thetford asap if the unit is uner 3 years old as it should be under warranty.
Thetford won't sell a replacement cooling unit, their only answer is that you need to buy a new fridge at over £600. I have this problem too and am looking for another solution but to luck so far
Refrigerator on rv keeps going out
Two reasons, first would be that the burner is dirty and needs cleaning. Second is that the thermocouple is either faulty or incorrectly installed. By this I mean that it might be slightly too far away from the flame to be able to conduct sufficient heat to keep the thermocouple open. This can happen when you park or drive and the rv is at different angles. So the flame does not heat the thermocouple enough and it shuts off the supply.
