20 Most Recent
AT&T ATT-992 Corded Phone Questions & Answers
Cannot record outgoing voicemail greeting
It's not in the manual for the good reason that the AT&T 992 isn't an answering machine. If you want to record an outgoing voicemail greeting, you'll have to do it on the voicemail system, not on the phone. If you need instructions on how to do that, you'll have to tell us the make and model of the voicemail system or answering machine.
Record an outgoing voicemail greeting
Record outgoing voicemail greeting
The AT&T 992 isn't an answering machine. If you want to know how to record an outgoing voicemail greeting, you'll have to tell us the make and model of the voicemail system.
I lost time on my
Feature ** 266344266344 is probably the password. Hit next until you see Time and Date, hit show and you can change it.
Pluged in the ATT 992
Hi Dewey,
Please make sure that the mute light is glowing when you are in the call as this will your microphone mute so your voice will not be heard at the other end.
1. Mute allows you to hear the other party, but the other party cannot hear you.
2. To activate this feature, press and release Mute button.
The MUTE light goes on.
3. To return to the conversation, press and release Mute button again.
NOTE: Switching from handset to speakerphone or headset, or from speakerphone or headset to handset, changing lines, and putting a call on hold will cancel Mute.
If still your voice is not transmitted properly to the other end, there there might be some problem with your phones microphone.
connect the receiver unit from any other similar phone and check. If works well, then its sure that your existing receiver's microphone is not working. To rectify this problem you may need to call for a phone service center.
I hope this is helpful to you
Thanks
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset
To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
- Make sure the new base unit is plugged in and turned on.
- Press and hold the "Menu" button on the handset until the display shows "Menu."
- Use the navigation buttons to select "Registration" and press "Select."
- Select "Base" and press "Select."
- The handset will begin searching for the new base unit.
- Once the base unit is found, it will be displayed on the handset's screen.
- Select the new base unit and press "Select" to complete the registration process.
- The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
