20 Most Recent
Nokia 7360 Cellular Phone Questions & Answers
Contact service on nokia 7360
Hi!
The first thing you do is to powercycle your phone you can do this by removing your battery when the phone is on. Then after 15 seconds insert your battery and then when nothing happens go to the place that has a strong signal. if nothing happens again try to contact your service provider because there might be a problem in your network.
Thanks!
Bluetooth and mp3
i want my 7360 to a bluetooth and mp3 activation,what should do?,and also my unit sometimes shutoff automaticaly and turn on after,and contact service appeared on screen. pls help me..?
How can i repormat my nokia 7360 because i cant
Try this. This works perfectly on nokia 6600 and i have formatting like this whenever im getting a virus attack.
Switch off and on . While the light on the screen appears hold these three keys, (Green call button+star Key*+number3. A vertical shade and the word " formatting "will appear on screen. Hold it till you finish the formatting. You will lose your phone memory. Im not sure whether this will work on 7360.
Restricted
you can get the Restriction code for your Nokia 7360 phone from
SimpleUnlocking.com and unrestricted your phone from Network lock easily.
10/15/2013 10:12:39 AM •
Nokia 7360...
Answered
on Oct 15, 2013
Hard reset of nokia 7360
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Master reset code
Reformatting a nokia 7360
1. Switch off your Nokia phone2. Now Press following key sequence *#7370# or *#7780#3. Enter Default lock code is 12345.4. While holding these buttons, press the power button and switch on the phone.5. Wait for message 'Format it
No signal
Hi,Try removing the simcard and re-loading it again.
Pls help me i have 7360 no signal
Maybe there is a problem with your service provider network.Try and use the sim in another handset to check if its working.Try and reinstall the firmware on your phone.
Prob
Sometimes it happens that we receive messages late or do not receive them at all.Most of the time signal is low means there may be some problem in your phone's battery.
I need a restriction code
hi you can use codes to unlock your mobile from a particular network .it will be helpful for me to guide you the exact place if you had specified the country and the provider to which the mobile is locked .however you can get the codes from here
onlinegsmunlock here they ask the imei number of the mobile .finally they will send you the unlock codes .
