20 Most Recent
Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio Questions & Answers
Radio is on but has no sound
the speakers might not be working,i would first check to make sure they are good and check the wiring to the speakers
Which fuse controls the rear hatch on my 1996 Chevrolet s10 blazer?
open the driver side door on the side of the dashboard there's a fuse boxthe same to use the works your power locks is the same one for ur rear but the best thing you can do is just look at your trucks manual if you have it it'if you don't have it look on Googleit will show you what number fuse it is
Steven its a 99 s 10 no power at the fuse ?
im moved you.
to S10
no power mean the voltmeter is not 12v>???????
the fuse has 2 ends, no power to me means both ends, right.>?
what fuse box, cab or bay?
that means the power ;means the fuse in cab is dead because the
MAIN fuse in the BAY is blown.
just like you home there are main fuses then sub branch fuses.
then the battery, its dead, all is dead.
1 step at time use the voltmeter and walk backwards to battery
and find the OPEN circuit. whomever it is. (chips fall where the may)
as will TRUE cause.
Trans gets stuck where it only has 2nd 3rd no od or 1rst gear
Do you have a code reader? If there is a message informing you that the transmission is in limp mode. You should be able to retrieve engine codes. From your symptoms I think that you either have an issue with fluid flow (clogged filter and/or screens), worn pump, low trani fluid level, trani fluid temp, possibly a correlation problem with the speed sensors, clogged air filter, dirty MAF sensor, clogged fuel filter, or blockage in the exhaust system. It will only be through diagnostics that these suggestions can be crossed out and narrowed down. Please let me know if that helps or if I can be of any more assistance, good luck.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
