20 Most Recent Visonik Dual Bass Box with Amplifier Car Audio Amplifier Questions & Answers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Visonik Dual... | Answered on Apr 21, 2014
You need to connect the Power wire (Most likely red wire with fuse) to the battery and run it to where you put the amp. You need to also drill a whole in the car and make sure it is grinded up and bare metal is shown. Screw the ground wire there with a bolt and nut. You will then need to run the rca cables from the amp location to either the back of the headunit if it has RCA outputs, or use a Line out converter, you can get them at best buy. Then you need to find your cars wiring harness code and figure out which is the remote ignition turn on and tap into that and feed that wire back to the amp to turn it on. Hook all wires up and make sure power and ground DO NOT TOUCH.
Visonik Dual... | Answered on Jul 24, 2011
you will need a amp install kit witch comes with a 15 ft patch cable power line for amp and a blue line for remote. these wires run from the radio to the amp. The blue wire is called remote it turns the amp on or off depending on the radio state. the patch cable is rca jacks on both ends the back of the radio should have the female part of the rca jacks hanging from it. The other end goes into the amp. and last but not least the heavy red wire will go from the battery to the amp usually there is a fuse holder that you need to put between the battery and the amp. As far as grounding just ground the amps negative to the car chasis some where.
Good Luck Hope this helps
Visonik Dual... | Answered on May 04, 2011
Make sure you have both power wires hooked up. There's the main power lead/cable going to to the battery, and the trigger wire from the accessory wire from the radio (antenna) to the amplifier. Hope that's what you were looking for. If so please rate my assistance and leave a testimonial.
Visonik Dual... | Answered on Dec 30, 2010
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Visonik Dual... | Answered on Nov 02, 2008
Which amp? The header doesn't specify.
Visonik Dual... | Answered on Aug 06, 2008
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Visonik Dual... | Answered on Jun 19, 2008
This usually involves removing the plastic bezel around the stereo. Sometimes these plastic bezels hold some buttons for air conditioning and heat, as well as the hazard lights button. These plastic bezels usually are just snapped in with metal clips on the back of them. You can pry them outward and with a good yank they will pop out. Once you have the plastic bezel around the radio removed, there will be 2-4 screws on the sides, or top and bottom. Once you remove those, the whole radio will pull right out of the dash. Then you have to un-clip the wire harness from the car, and unplug the antenna cable. If you plan on putting a different stereo in the car, KEEP the mounting bracket around the stereo, as well as the "wiring harness" that was used to plug into the vehicle harness. That will save you about $50 in parts to put a new stereo in.
Visonik Car... | Answered on Aug 23, 2016
To be absolutely sure of which terminal is positive and which is negative, we will use a 1.5 v battery to have the speaker react as though it is playing music.
* special note * do not use any more than 1.5 v as it may damage the speaker coil
As we know, batteries are marked positive, negative, or both ... we will use this to our advantage when hooking up the battery to our speaker.
To start the process, temporarily attach a short piece of wire to each terminal of the speaker (be sure to either use wire that is marked, or wire of differing colours to help determine which terminal is which).
In our example, we used standard speaker wire which is "polarized" (one wire is made of copper and the other is made from tin .. interestingly, this serves no electrical purpose)
Once you have connected the wire to your speaker, proceed to briefly touch the free ends of the wire to the battery terminals (as shown below). In some cases, extended contact with the battery has caused cancer of the voice coil (ie. blown speaker)
If the speaker moves OUT when the battery is first connected, the battery is connected in proper alignment. Be sure to take note of which wire is connected to the positive terminal of the battery as this is your speaker's positive terminal.
Visonik Car... | Answered on Aug 18, 2012
Visonik Dual Bass Box with Amplifier Car Audio Amplifier Logo
10 questions posted
Top Visonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Pierre Laplante
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Visonik Car Audio & Video
Most Popular Question
don 39 t know hook up amp came
  • Car Audio & Video
