20 Most Recent
Bushnell Trail Scout 11-9500c Digital Camera Questions & Answers
MY MEMORY CARD WILL NOT LOCK INTO PLACE WHEN I
Most likely the SD card is not being pushed in far enough to lock into place. You really need to use your fingernail to push it in past flush until you hear a clicking sound, at which point the card will lock into place.
Here are full instructions for insertion and removal of the SD card: Insert the memory card with the metal contacts going into the slot first and facing up at you. In other words the SD card label should be upside down when you insert it this way. You need to push the card in past flush to have the spring mechanism lock the card into place. To get the card out of the slot, push the card in past flush and then the spring mechanism will release it. You will hear a click when the card locks into place or is released from the slot.
I have a Bushnell trailscout
Probably the first thing to try is formatting the card. There should be a function in the setup menus to do this. If it won't format or gives an error when you try the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Bushnell trailscout 119900.\r\nforgot password
You can reset it. Write down the serial number of your camera and contact Bushnell support at 800-423-3537 pressing option 2 in the main menu.
You will be guided to reset your password. You need to have your camera serial number with you when you contact them.
Wont take pictures
If every thing is working on the cam but the camera, and your cam has a built in memory, take the memory card out. Try using cam with just built in memory. Sometimes the cam wont format right with the memory card. Don't know why, but it just happens. If this works, you'll have to get another memory card. If the cam doesn't read the memory card, it will still work, but it won't take pictures.
Forgot password
reformatt the whole hard drive or go to microsoft.com download ther disk reset tool see if it works ok
Trail Scout corrupting SD Card
camera has a 2 year warrenty, this is a manufacturing problem, sent mine in and they are sending me a new unit to replace the old one.
Not taking pictures
The sensor sounds bad. The communication seems to have a too long of a delay. Meaning it is not snapping the shot as soon as the sensor goes off.
RI have a bushnell trail
Download the firmware from their site onto a newly formatted sd card...and it should sort this out.
