FixYa.com
ASUS MM17T  17 inch LCD Monitor
All Products > ASUS > Monitors
Problems with ASUS MM17T 17 inch LCD Monitor?
Search inside ASUS MM17T 17 inch LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS MM17T  17 inch LCD Monitor RSS Feed Post a New Problem
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
How to Adjust the Number of Colors...
How to Adjust the Number of Colors Displayed on a Monitor?
1 Solution
how to fix your speakers
how do you fix the speakers built into the moniter?
1 Solution
Redless screen
the color red is totally missing from my monitor.at times the red returns for a short while then disappears.also there...
2 Solutions
Connecting MAC monitor
I have MAC monitor, 17 inch flat screen with cabinet made from clear plastic. One of the late MAC models. Unfortunately...
1 Solution
How to remove internal capacitor on a...
Does anyone knows and could share their tips on removing and replacing an internal capacitor on a flyback? what are a...
1 Solution
TDA4854 replacement..
Does anyone knows whether I can replace TDA4854 with TDA 4858? Thanks.
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4
Size17 Inch
Color Depth24-bit (16.7M colors)
Contrast Ratio600:1
Brightness400 cd/mē
Max. Resolution1280 x 1024
Dot Pitch0.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time8 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s) · Headphones
Audio InputLine In (3.5mm)
Regulatory ApprovalBSMI · CE · TUV GS · UL · C-Tick · CB · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-99 · FCC · GOST-R · CCC
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal30 - 80 kHz
Max. Viewing Angle - Horizontal150
Max. Viewing Angle - Vertical130
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 720 x 400 · 640 x 350
Synchronization Range - Vertical55 - 75 Hz
Dimensions
Depth7.09 in.
Height15.35 in.
Width14.96 in.
Weight9.37 lb.
Warranty
Warranty1 Year
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
