20 Most Recent RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case Questions & Answers
Please spell the name of the speakers again, I have no listing...accordianman
RaidMax SIRIUS... | Answered on Oct 15, 2011
Here are some solutions:
1. Try to use some silicon oil in fan apertures to decrease rub
2. Try to manually (look for a mainboard's service software settings) decrease rotation speed if available
3. Less recomended: disconnect fan cable from mainboard and don't stress your computer (try not to overheat, - work with software that uses less resources) and buy a new one when available
RaidMax SIRIUS... | Answered on Jan 28, 2009
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
RaidMax SIRIUS... | Answered on Dec 28, 2008
CHECK FOR UR SMPS AND CALL LOCK IT
RaidMax SIRIUS... | Answered on Feb 21, 2008
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
RaidMax SIRIUS... | Answered on Feb 03, 2008
Test the PSU. Unplug it from the motherboard and then with nothing connected, short the green wire to any ground (usually a black) using a paperclip and it should come on and stay on if the problem was with the motherboard/computer but if it shuts down, then you know the problem is the PSU itself.
If the PSU stays on under no load, then one possibility is you had too much connected to it and it shut down as a protective feature. The Bios would not beep if the PSU is shutting itself down. Also make sure you have the internal speaker connected. It's possible you just can't hear the beep because there is no speaker connected or it may be connected to the wrong place.
Don't throw away a defective power supply. It is worth a couple bucks as parts for an electronics enthusiast. Keep it out of the landfill.
RaidMax... | Answered on May 08, 2015
All new power supplies have a voltage sensing circuit. they need to have a load on them to start.
RaidMax... | Answered on Oct 16, 2013
anywhere where there are earthquakes under the sea.
Tsunamis occur most often in the Pacific Ocean and Indonesia because the Pacific Rim bordering the Ocean has a large number of active submarine earthquake zones. However, tsunamis have also occurred recently in the Mediterranean Sea region and are expected in the Caribbean Sea as well.
NOAA Center for Tsunami Research - FAQ results
https://nctr.pmel.noaa.gov/faq_display.php?kw...%20Hal%20Mofjeld
https://www.google.com/search?client=firefox-b-d&q=where+do+tsunamis+occur
Computers &... | Answered 5 hours ago
I would not recommend Your Kids playing on Your Phone............
Computers &... | Answered 7 hours ago
RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case Logo
11 questions posted
Top RaidMax Computers & Internet Experts
Alun Cox
k24674
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • RaidMax Computers & Internet
Most Popular Question
raidmax sirius case not turning
  • Computers & Internet
