20 Most Recent Itech Blue Pro Bluetooth Stereo Headphones Headset Questions & Answers
The Itech manual I have says to try 0000 or 8888 or 1234 Codes to Sync it up. I did the usualy 0000 until I was blue in the face then read the Chenglish manual, 8888 worked for me. These Itechs are a bit different but VERY kewl.
Itech Blue Pro... | Answered on Sep 01, 2017
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Itech Blue Pro... | Answered on Dec 24, 2016
0000
Itech Blue Pro... | Answered on Oct 30, 2010
Mines a Li-Ion Pack. All Lithium Ion Batteries put out 3.7 VDC.
Itech Blue Pro... | Answered on Feb 16, 2010
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Itech Blue Pro... | Answered on May 03, 2009
Make sure you have a good connection
Itech Radio... | Answered on Mar 13, 2019
The password to access it is "8888"
This device is Bluetooth certified so it uses all the conventional ways of setting it up as any other device of its kind. Simply press the function button until it lights up red and blue intermittently. That will put the R35 on "Find Me" mode. After that just use your cell phone or Bluetooth dongle to find any devices and you will see it available.
Itech Radio... | Answered on Mar 21, 2012
The pairing code is simply 0000. It is written in the instructions manual.
Itech Radio... | Answered on Oct 07, 2009
Itech Blue Pro Bluetooth Stereo Headphones Headset Logo
Popular Tags
17 questions posted
Top Itech Radio Communications Experts
Anthony Ward
Anthony Ward
Vernon Taylor
Kardoc
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Itech Radio Communications
Most Popular Question
tech blueband bluetooth stereo
  • Radio Communications
