20 Most Recent Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF Questions & Answers
Whirlpool's filter finder page: Water Filter Finder Whirlpool Refrigeration Cooking Dishwashers Laundry...
You can also just Google Whirlpool ed25tq water filter location which will show videos of the process as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Whirlpool 25.2... | Answered on May 14, 2016
Is there an ice maker in the freezer? Check it. There could be a leak there. Check the defrost tube. When the freezer goes into defrost, the water has to exit the box through a tube, of some sort.
Whirlpool 25.2... | Answered on Aug 17, 2014
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Whirlpool 25.2... | Answered on Dec 12, 2013
Ok unplug your box. go to the dispenser remove the tray. Now pull down on the bottom cover. this will unlock the cover. Right behind the cover is a plastic swtich holder. You have a broken pin that holds the swtich. replace this and you will back in order. hope this helps.
Whirlpool 25.2... | Answered on Aug 21, 2011
Which fan? Condensor or Evap. ac or dc? Could be big problem, main board. Could be fan. Ck power to same and or blockage.
Whirlpool 25.2... | Answered on Aug 13, 2011
I would get it. I like the fact that the control is old school $60 (none electronic). It has a old school defrost timer. Parts are reasonable timer $20 heater $30 terminator $20 bucks compressor $230 bucks. Looks like it uses R134A freon which is environmentally safe and available to anyone. Not bad at all compared to the crappy electronically controlled models of today. Today's electronically controlled ice boxs are subject to spike surge electrical storm damages etc. Even though this one could be hit by storms too, it is much less likely to happen and you don't have to be a rocket scientist to work on it. Looks like it might be a great investment.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool 25.2... | Answered on Jun 21, 2011
If it's old change it but I would also check to make sure the ice maker itself is not corroding on the inside, When they get older the paint comes off in the tray.
Whirlpool 25.2... | Answered on May 17, 2011
Put an inline filterin the fridge water feed line or flush out the line.
Whirlpool 25.2... | Answered on Apr 29, 2011
You don't say how old the frig is ... you cant have a frig run like this. On one day ... off the next ... slam the door and it works ... Either get a new frig of get this one repaired professionally. Probably best to get a new frig. I would guess minimum service call charge will be $250.00
Whirlpool 25.2... | Answered on Apr 05, 2011
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Whirlpool 25.2... | Answered on Apr 01, 2011
mite need regassing...................
cheers
Whirlpool 25.2... | Answered on Mar 27, 2011
yes u can try new newspaper crumpled up all in the ref. and freezer.. it will absorb the smell. but make sure to wipe it again with clorox or bleach water. also charocal u know bar-b-q char. left inside will absorb a lot of smells. ok try that.
Whirlpool 25.2... | Answered on Feb 13, 2011
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Whirlpool 25.2... | Answered on Jan 17, 2011
Refrigerators Logo
Popular Tags
51 questions posted
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
looking buy used whirlpool ed25pq 300
  • Refrigerators
