20 Most Recent
LaCie Dupli DVD121 DVD±RW Dual Layer Burner Questions & Answers
CDS BURN BUT CANNOT PLAY WHY?
You mean, you burn the CD in your PC but you can't play it in external CD player ?
Maybe you didn't burned it in "movie" mode, just burned in "data" mode. As you know, CD player can't play .avi or .mkv or other video formats. They only can play movie in .DAT format, and when you burn in "make a movie" mode, the burner will convert your movie to this format so you can re-open your movie via CD player.
Or there is an error during the burning time, if this happen then you have to re-burn your movie into another CD.
Hope this help and be kind to rate this answer.
(^_^)
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
