20 Most Recent
iHome Ip21 Ipod/iphone Dock/alarm Clock Questions & Answers
How do I open my iHome IP46 to replace battery?
Looks like it was not designed to be repaired. You have to remove the speaker grills by prying them up. They are glued in. Then find 8 screws (not the small speaker screws) then you still need to pry it apart at the only seam that you can find that goes around the unit. The battery has three small phillips screws and it is unplug able. The only hint that they expected it to be repaired. It will be a mess at the seam when you finally get it apart using flat blades screw drivers (careful doing this). Now for the funny part. I unplugged the battery and plugged it backing and the unit turned on. Strange. Hope this helps. It actually has pretty good sound for its size. If I put it back together and it fails again, it will be trashed..
