philips 42 plasma tv . Been told the part that needs replacing BOOTS up the screen. Tv part no...
(More)
philips 42 plasma tv . Been told the part that needs replacing BOOTS up the screen. Tv part no 42PFP5332D-37
Is there a way to turn off(i mean really turn off, not standby) the Philips 42PFP5532D with a button...
(More)
Is there a way to turn off(i mean really turn off, not standby) the Philips 42PFP5532D with a button on the remote?
tv keeps clicking when trying to come on clicking sound coming from back of tv .can see green lights...
(More)
tv keeps clicking when trying to come on clicking sound coming from back of tv .can see green lights flashing inside back of tv
42 in plasma turned off yesterday and now when I try to turn it on it just clicks blue power light...
(More)
42 in plasma turned off yesterday and now when I try to turn it on it just clicks blue power light comes on.
my phillips 42 inch plasma tv is 2 years old and  just clicks when I turn it on.It would...
(More)
my phillips 42 inch plasma tv is 2 years old and just clicks when I turn it on.It would click for about 30 minutes and then come on, but yesterday it did not come on at all. I read on line that this is a problem with the lamp or ballast. The lamp could cost $110 to $175. What should I expect to pay a technician? If it's more than the lamp what else could it be? What is the ballast?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
