20 Most Recent
Aztech MDP7800U Agere 1648C-TV5 56K PCI Data/Fax Modem Questions & Answers
(agere sv92p too)How to get this fax modem driver
I was looking for the same driver and came across you needing it too. This driver does work I linked to does work. I just used it on xp sp3. If by some chance you cannot get it to work, just look for 'lucent sv92p' as Lucent and Agere are the same company.
http://members.driverguide.com/driver/detail.php?driverid=123626
You will either need a free membership or look at 4 or 5 pages of ads to download this driver. Sorry, but I could not find it at any other sites that did not require a membership.
Someone just told me to try this website. I am
You need an app that will display all the wifi in the area, by power and channel. I'd suspect that you are getting interference on the same channel. Try a different channel, move the antennas around, make a directional antenna, reduce the shielding between you and the router.
Aztech homeplug 117EW model, unable to operate
Have you got any electrical work done in your place? I don't know your location o can't comment on that but here in India and in places we have 3 phase supply in every home. For your device pair to function properly they need to be on the same phase. Won't work otherwise. Try plugging both the devices in the same room where you know for sure that the plugs are on the same circuit. See how it responds.
Modem:AZTECH DSL605EW
Hi i have no
It will be lit up if there's a Ethernet Cable Connected to either of the 4 ports. If you will be using a Hardwired connection to connect the Computer to the router you will see that the light on the port where the ethernet cable is connected will lit up. However if you will be using wireless connection then it wont lit up.
Thanks for using Fixya.
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
