20 Most Recent
Bose Awrc1g Wave Radio Cd Player Only - Broken Not Working Questions & Answers
Bose Wave unplugged now it wont power up
The power supply and power regulation circuits on these particular models can be finicky and fail in various assorted manners, causing a no power up condition. This is not something an untrained person should attempt to repair. If there is a possibility that liquid seeped into the unit from a spill (common) then that can present its own set of problems. We service hundreds of these units. CET Services, 117 Windsor Ave., Hurley, WI 54534 //
[email protected].
Why did left speaker stop working?
If the speaker is not defective, a common problem with the AWR1CG and P models is liquid damaged circuitry. Where openings in the top case appear over the circuitry, spilled liquid drips down and may damage, or over time badly corrode, the circuit board traces, small through-connections, and/or electronic components. This is not a repair an untrained/experienced person should attempt. We service many of these liquid damaged units with good success rate. CET Services, 117 Windsor Ave, Hurley, WI 54534 //
[email protected].
Cd carriage does not always load cd properly
Yes,as rightly suggested,dirts can cause the optical lens to reject some CDs.Use a a CD cleaner to clean the optical lens.If the problem persist,then you will need a qualified service personel to replace the lens.
Cd won't turn or makes clicking sound when turning. Either way won't play
Remove the cd then.
remove the cd cover then
tutn on the device without cd and look at the cd reader if there is red light. If so turn the potentiometer installed with th cd reader board a little bit in one direction and notice the light.if mire light came on put the cd and test
if not ok replace the cd reader
if the light decreased when you turned the potentiometer . Turn it on the other direction carefully untill there is more light
if there is no light from the cd reader. Unplug the cable installed in it and clean the terminals carfully with suitable cleaner then plug and test . And if still no light . Change the cd reader
nnote. Usually its a cd reader fault
Bose wave radio doesn't turn on with the remote but one time in 20 to30 times pushing the power button.
You can check with new battery in the remote. Next you point a digital camera, a smartphone should do fine, at the infra red transmitter on the front of the remote and then look on the camera screen if you see the ir light flash different pulses for each button. Infra red light can not be seen but a digital camera shows it really well. Confirm this with another remote. Now you know if the remote functions right. Remotes are available on-line or one can use a universal type remote. The IR receiver is often welded onto the circuit board. This means that it is not right behind the front panel window. It can be obstructed, perhaps by dust or displaced. This is generally speaking.
