20 Most Recent Targus PAUH217U 4-Port USB Hub Questions & Answers
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Targus PAUH217U... | Answered on Mar 30, 2016
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Targus PAUH217U... | Answered on May 18, 2014
Use any USB cord available at electronics stores that has a male on one end and a female on the other, obviously of the correct length.
Targus PAUH217U... | Answered on Jan 23, 2013
Hi you may need to install the driver for that "Hub" also make sure that it is compatible with your system? make sure that the unit is USB compatible, usually it must be a USB 1 or USB2 version.. but in any event when it is first plugged in there should be a **** **** noise that indicates that it has been inserted, Windows should then detect it and install the necessary hub drivers, if it doesn't do so, then you may have to upgrade your USB layer? Do you have all service packs installed?, or even perhaps remove and reinstall the USB layer, to do this go to control panel, and then system, then device manager, find the USB part and right click on it and REMOVE everything and reboot, then windows will reinstall the layer again, and now you should be able to insert the Hub and it should be detected, have the driver install and work.
Also have a look at these troubleshooting links below they will assist you too..
http://support.microsoft.com/kb/310575
http://webcache.googleusercontent.com/search?q=cache:bUVhSp2zU3QJ:www.earthtym.net/USB-solutions.htm+troubleshooting+usb+ports&cd=3&hl=en&ct=clnk&gl=nz
Targus PAUH217U... | Answered on Sep 19, 2011
This USB hub is not powered by an AC adapter. Therefore, some devices that need more power will not work well on it. You don't mention what it is you are pluggin into it, but I suspect this may be your problem. Devices like webcams pull way too much to be on a hub without AC.
Did I solve your problem? If so, please rate this. ty.
Targus PAUH217U... | Answered on Feb 26, 2010
Try Snappy Driver Installer - Install and Update Drivers is Free and no Ads or Malware
https://sdi-tool.org/
Targus Computers... | Answered on Feb 27, 2019
I found one on Amazon.
Wireless Presenter, ON THE WAY RF 2.4GHz Wireless Presenter Remote Presentation USB Control PowerPoint PPT Clicker. see the link below. https://www.amazon.com/Wireless-Presenter-WAY-Presentation-PowerPoint/dp/B06Y5ZGPX1/ref=sr_1_1_sspa?ie=UTF8&qid=1542643943&sr=8-1-spons&keywords=targus+presentation&psc=1
Targus Computers... | Answered on Nov 19, 2018
I have the same printer; first need install the drivers, according woth your OS (Operative System), this drivers can find and donwload from this link: printers_and_all_in_ones/Epson_Stylus_T13
Just select your OS and donwload, install the driver and follow the guide step by step.
Good luck.
Targus Computers... | Answered on Nov 13, 2018
google targus with make model and serial and go to support/download and get user manual.pdf
Targus Computers... | Answered on Sep 30, 2018
ManualsLib has the User Manual for the Targus AMP01US Wireless Multimedia Presenter with Trackball here: https://www.manualslib.com/products/Targus-Amp01us-7090628.html . You can download the manual from the Download button in the upper left corner of any page after the title/table of contents page.
I hope this helps.
Targus Computers... | Answered on Sep 02, 2018
Targus PAUH217U 4-Port USB Hub Logo
8 questions posted
Top Targus Computers & Internet Experts
J John
Raj Patel
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Targus Computers & Internet
Most Popular Question
cable targus 4 hub usb2 model pa055u
  • Computers & Internet
