20 Most Recent M-Audio Audiophile 192 Sound Card Questions & Answers
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
M-Audio... | Answered on Feb 21, 2014
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
M-Audio... | Answered on Feb 18, 2012
it supports all operating systems ... go through the link given below download drivers and install it
http://driverscollection.com/?H=Delta%20Audiophile%20192&By=M-AUDIO
M-Audio... | Answered on Dec 23, 2011
it supports all operating systems .. the drivers you are installing may be corrupted here is the link below download drivers and install it
you cant download a sound card but you can download sound card drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers
http://download.cnet.com/m-audio-delta-drivers/3000-2120_4-14794.html
http://download.cnet.com/delta-series-digital-audio/3000-2120_4-34788.html
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for ie:intel laptop
(be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
M-Audio... | Answered on Sep 01, 2011
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
M-Audio... | Answered on Jun 11, 2011
At first you just load your sound card driver, install it. After installation you must restart your computer and you get sound.
M-Audio... | Answered on May 08, 2011
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
M-Audio... | Answered on May 06, 2011
Check device manager if there's a problem with the device. Tell me if it has a question mark or exclamation mark on it. Also check if your audio is on mute.
M-Audio... | Answered on Apr 10, 2011
You can get the drivers for your computer from lenovo's website. (www.lenovo.com)
Click on the link below. You will be directed to the R52 1858-MQ8 page.
>>>>CLICK HERE<<<<
I hope this helps.
M-Audio... | Answered on Jan 31, 2011
Did you check the manufacturer's website?
Or try a driver finder program to scan all devices and find the right drivers.
M-Audio... | Answered on Sep 14, 2010
you must go into the cmos and diable the onboard sounds when cp starts hit either f1 or f2 or del key to inter cmos be sure not to disable anything else the sound are usly found at the pirephels esxcuse spleeing
M-Audio... | Answered on Jun 25, 2010
I was speaking to this custom pc company about my identical problem. Turned out that I had the wrong speaker setting in Windows. It was set to 2.0 when it should have been 5.1 and hey bingo, it worked. Not sure if thats what your problem is but sounds the same. Ted
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
First, download the latest driver for your card.
Turn off PC and remove the sound card, then turn on PC and carry out the following;
1. Deinstall the driver and reboot the system.
2. Execute the Windows program regedit and search all items for "Delta".
3. Delete all items and groups of items which point to "M Audio Delta".
4.Turn off PC, re-install card and reboot the system.
5. Install the latest M Audio driver.
M-Audio... | Answered on Jan 13, 2010
Assuming you are running XP.
If it hasn't installed the device ,
uninstall device and reboot then restart
device should autofind and self install
reboot to save settings,Update SP2 also....
Let me know how it goes thanks
Please rate me ,,,Cheers
M-Audio... | Answered on Nov 26, 2009
The sound properties are really "toucy" in this version of Windows.
Check here for possible resilutions.
http://www.microsoft.com/library/toolbar/3.0/sitemap/en-us.mspx
M-Audio... | Answered on Jul 08, 2009
M-Audio Audiophile 192 Sound Card Logo
30 questions posted
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
sir lenovo r52
  • Computers & Internet
