I don't have a manual
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
