see the solution; God bless you
How to determine a clog in your hose
Take your central vacuum hose and connect it directly to the dirt
canister. After turning on the vacuum if the hose has normal suction
here then the clog exists in your tubing.
Click here for help with tubing clogs.
But, if you experience reduced suction at the canister then your hose is clogged. See Solutions below.
Plug hose in reverse into the inlet located on your unit and turn on the system. This should aspirate the clog out.
Or,
remove the hose from the inlet and push a garden hose through hose to
push out the clog. Most importantly, the garden hose must be turned off
and there should be absolutely no water entering your vacuum hose.
Or, remove the hose from inlet and drop in a heavy object such as a screwdriver to push out clog.
