20 Most Recent RCA DRC627N Portable DVD Player Questions & Answers
How do I get the lens to move to read the disc?
Buy a new player. Not worth fixing.
6/5/2014 6:33:27 AM • RCA DRC627N... • Answered on Jun 05, 2014
No Power at all
it mean its broken sorry but you cant play it againg go and buy new one
6/2/2013 9:41:28 AM • RCA DRC627N... • Answered on Jun 02, 2013
Buttons are not working
check for an stuck up button, or the tact switch doesn't have contact which need replacement.you can use an ohmmeter to check weather their is a resistance or worn out.
10/3/2012 6:14:19 AM • RCA DRC627N... • Answered on Oct 03, 2012
0answers
Wont play and we had tied everything
Hello, welcome to Fixya!Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.If non of the above solves the problem, then know that you need to replace the laser to a brand new one.To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.Once this us done, your player will play all DVD discs again.Good luck.
11/3/2011 1:17:18 AM • RCA DRC627N... • Answered on Nov 03, 2011
2answers
RCA DRC630N portable dvd player - blank screen, controls don't work (but powers up)
Im in the same boat. i have 3 and not one works!!
6/7/2011 2:53:45 PM • RCA DRC627N... • Answered on Jun 07, 2011
2answers
Como destravo o dvd rca
Hi Thanks for using FixYa. This website usually provides support in English however, please follow these step by step instructions to unlock your DVD Player and check below for instructions in your language: - turn the player on without any disc inside - enter the code 321 789 456 before the player menu appears - select 'all' in the appearing list for regionfree - turn the player off Please do accept the solution if the issue is resolved or else revert for further assistance. Thanks Rylee_____________________________________________________________ Oi
Obrigado por usar o FixYa. Este site geralmente fornece suporte em Inglês no entanto, por favor, siga estas instruções passo a passo para desbloquear o DVD Player:
- Ligar o aparelho sem nenhum disco no interior
- Digite o código 321 789 456 antes do menu jogador aparece
- Selecione "todos" na lista que aparece para regionfree
- Desligue o leitor
Por favor, não aceitar a solução se o problema foi resolvido ou então voltar para obter mais assistência.
Obrigado
Rylee
4/17/2010 3:02:55 AM • RCA DRC627N... • Answered on Apr 17, 2010
My son has a portable sylvania portable dvd player
most hardware stores sell wire but it would be cheaper to use electrical tape.
1/20/2010 3:30:02 AM • RCA DRC627N... • Answered on Jan 20, 2010
It will not read discs/dvd and it will not do
try cleaning the optical lens. blow dust out of it. if it still won't read dvds, you may need to replace it.
12/14/2009 4:49:22 PM • RCA DRC627N... • Answered on Dec 14, 2009
2answers
Need a replacement power cord
I don't know if you use eBay, but this is where I found a replacement for you:
Click here!
All the way at the bottom there are two different people who have what you need.
5/31/2009 7:12:01 PM • RCA DRC627N... • Answered on May 31, 2009
Dvd player
Is there a small reset button on the back of the dvd player or inside where you put the DVD in. Push the button and see if that makes a difference.
7/26/2008 1:57:27 AM • RCA DRC627N... • Answered on Jul 26, 2008
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
RCA DRC627N Portable DVD Player Logo
16 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
wont play tied everything
  • Televison & Video
