20 Most Recent Dyson DC28 Animal Upright Vacuum New DC 28 Animal Questions & Answers
The belt is broken that spins the brush. Button is warning you that something is wrong.
Dyson DC28... | Answered on May 19, 2017
Check the belt that drive the brush not broken or brush not clogged up.
Dyson DC28... | Answered on Oct 01, 2016
The filters may need replaced and/or it may have a clog somewhere.
Dyson DC28... | Answered on Mar 08, 2016
Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having trouble with your Dyson vacuum. There are a few potential reasons as to why your vacuum brush is not spinning. First, the belt may not be attached completely to the brush and as such may not be spinning. If this is the case simply readjust the belt so that it is aligned both on the brush and the motor.
Second, it may be related to the brushroll. Check to make sure that there is nothing clogged in the bristles or lodged in the bearings preventing it from spinning. You should regularly clean this area out to make sure your vacuum is running optimally.
You can purchase replacement parts for your Dyson direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Dyson DC28... | Answered on Aug 13, 2015
Hi, this is Jim with Crucial Vacuum,
Detach the hose and stretch it out completely, if the sock is in a hard to reach place use a broom handle to push it out. Be careful to mind the edges of the hose you don't want to cause a tear, which would lead to poor suction.
You can purchase replacement parts for your Dyson DC23 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc23-pre-filter-part-913394-01.html
Jim Thompson
Dyson DC28... | Answered on May 15, 2015
You can download the manual here: http://www.retrevo.com/support/Dyson-DC28-Animal-Vacuums-manual/id/23599ci662/t/2/
Here is the link to the Dyson DC28 support page: http://www.dyson.com/support/dc28/dc28-animal
Dyson DC28... | Answered on Mar 05, 2015
I took mine off and made sure all the dust went into a bag. Then I used damp paper towels to clean the inside walls of the bin. If there was any gook stuck, I used a lil dish soap. Never immerse the bin, or replace it on the vacuum wet.
Dyson DC28... | Answered on Oct 14, 2014
Hi Chris, it's Jack at Dyson.
Your DC28's selector pad and/or on/off switch will flash to let you know if there's an issue with the vacuum. This could mean that something is jamming the brush bar, or that the vacuum is set to the wrong height for the type of flooring you're cleaning.
To check the cleaner head for any obstructions, and to remove any threads, hair or other debris from the brush bar, please follow the steps shown in our video guide:
This should resolve the issue, but if your machine continues to flash, please contact us directly so we can talk you through some further troubleshooting checks. You can reach our experts by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Dyson DC28... | Answered on Oct 06, 2014
Hi Lynda, it's Jack at Dyson.
DC28's brush bar is not designed to be removed by the user, and attempting to remove it could cause damage to the machine not covered under warranty.
If you're having any difficulty with your DC28, I would encourage you to get in touch with us directly so we can provide further advice. You can reach our experts by calling on 1-866-693-9766 (US) or 1-877-397-6622 (CA).
We'll look forward to speaking with you.
Dyson DC28... | Answered on Sep 29, 2014
Hi there, it's Jack at Dyson.
If your DC28 won't seem to work at all, it's worth testing the machine in other outlets, just to rule out any issues with the wall socket itself.
If you're still experiencing difficulty with your machine after giving this a try, please get in touch with our experts directly so we can take you through some further diagnostic checks. Once we've determined what's causing the fault we should be able to recommend the best course of action. If a repair or replacement part is needed we can also confirm if this is covered under your Dyson 5-year parts and labour warranty.
You can reach us by calling 1-866-693-9766 (US), 1-877-397-6622 (CA).
Dyson DC28... | Answered on Sep 24, 2014
I'm sorry to hear you're having difficulty reclining your DC28.
It's possible this could occur if an item such as a pen or pencil has been accidentally vacuumed up, and is jamming the changeover valve mechanism. This is easy to check for - after turning off and unplugging the vacuum, lie the machine on its side and open the duct inspection port, then remove any objects or debris:
If you can't find anything, but continue to experience difficulty reclining your vacuum, please get in touch with our experts directly so we can provide further assistance. You can reach us on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Dyson DC28... | Answered on Sep 17, 2014
If your DC28's on/off switch is flashing, the machine is warning you that something is wrong. It's worth checking the cleaner head and brush bar are free of any threads, hair or other debris or obstructions, as shown in our video guide:
This should resolve the issue, but if you'd like some further advice from our experts after giving this a try, you can reach us by calling 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Dyson DC28... | Answered on Sep 11, 2014
The motor is burned out or the brushes in the motor coil need to be replaced.
Dyson DC28... | Answered on Sep 10, 2014
From what you've described it sounds likely that the key is in the U-bend or one of the airways. This is easy to check - after turning off and unplugging the vacuum, lie it on its side as shown and open the airway inspection port to locate the item:
I hope this helps, but if you need any further guidance from our experts you can reach us by calling 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Dyson DC28... | Answered on Aug 20, 2014
Dyson DC28 Animal Upright Vacuum New DC 28 Animal Logo
31 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
accidently sucked up key didnt go into
  • Vacuums
