20 Most Recent GE JVM1750DM Microwave Oven Questions & Answers
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
10/16/2017 8:54:30 PM • GE JVM1750DM... • Answered on Oct 16, 2017
0answers
Jvm1750wmc02
Be the first to answer 1/14/2014 3:49:44 AM • GE JVM1750DM... • Posted on Jan 14, 2014Be the first to answer
Microwave looks like everything is working but it
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
5/14/2011 11:11:29 PM • GE JVM1750DM... • Answered on May 14, 2011
GE microwave model JVM1750DM does everything
Chances are the magnetron has failed, "heats food" the other possibility is the high voltage capacitor and diode. Repairs will approach the cost of a new microwave oven.
4/19/2011 2:59:45 AM • GE JVM1750DM... • Answered on Apr 19, 2011
How do I change the Charcoal filter on my GE
the charcoal filter is either in the top of the microwave or on the bottom, but you can order from APDEPOT.COM, Repairclinic.com or searspartsdirect.com
2/23/2011 3:17:23 AM • GE JVM1750DM... • Answered on Feb 23, 2011
Error code F-3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
11/4/2010 8:44:35 PM • GE JVM1750DM... • Answered on Nov 04, 2010
JVM1750DM1BB microwave vent fan button not
sound like you have a problem with the eschelon, maybe a bad or sticking button
i would replace the entire control board
its very easy
unplug the machine, open the door and remove the one screw just inside the door jam
lift up and out, write down all your plug positions and remove the wires
call appliancepartspros.com
and order this part
AP3993712
its a repalcement control board
120.00
10/17/2009 5:03:57 PM • GE JVM1750DM... • Answered on Oct 17, 2009
I've got a GE Advantium 120/Model ZCS1001KSS01, the display will get lines thru it, and comes in and out of view, and will always finish its cycle. however, when you go back to use, it is dead.
The problem with your Display of your GE Microwave/Speedcooker is not the Digitron WB27X10856 display board? The flickering and ultimately failure over of the display is due to the WB27X10861 GE microwave control board which is a rebranded (LG 6871W1A417/6871W1A417A board) which GE then sells as a markup. The princple purpose of this board is to convert (i.e. rectify) AC to DC at various voltage levels needed by the rest of the microwave to run their control circuits in the microwave. A portion of the GE microwave is always on so the AC/DC supplly is always on. Overtime the electrolytic capacitors in a section of the board fail or degrade to a point they the DC suppy starts to produce ripples in the DC power supply which results in circuit board failures. These ripples produce deep spikes of voltage of 120 Hz that the other circuits are sensitive too. I just exmined a failed WB27X10861 board and measued the capacitance of each of the seven electroylic capacitors. Of the 7 capacitors, 2 had failed over time. The others 5 have degraded 10 to 15 percent but still within their design spec. The two that failed, C07 - 1000uF 25 V had a measured value of 207uF and the other C08 - 220uF had a measured value of 13uF. There was no visible bloating on either SAMWHA SG capacitor. Nomally, these capacitors are rated at 2000 hour at 85 degree C. 2000 hr is only 83 days, but since the voltage is less and the temperature is probably 40 to 50 degrees inside the capacitor these capacitors may last 10 years. They harder they work the shorter the lifespan. There are two solutions, either purchase a new replacement control board or replace the failed C07 and C08 capacitors within the failed board with better ones. You can easily buy 10,000 hour , 105 degree C rated capacitors for probably 25 cents more than 2,000 hour capacitor. Most people don't have the resouces to repair a board so buying a new board is their only solution. Don't buy a used board on ebay because a used board is probably on the verge of failure.
4/8/2024 10:50:08 AM • GE Microwave... • Answered on Apr 08, 2024
3answers
I need a manual for a GE Spacemaker model 7-4290 . Or access how to set the clock time. I can't find it anywhere online.
Take model # to searspartsdirect.com. They typically have manuals in parts listings.
3/17/2024 6:18:10 AM • GE Microwave... • Answered on Mar 17, 2024
2answers
Can the GE 3-in-1 Countertop microwave be installed inside a cabinet?
No, because it is an Air Fryer and Broiler as well. It would generate too much heat and no where for it it escape. You would need to use it on a counter as described or buy an over the range model.
GE 3-in-1 Countertop Microwave Oven, Complete With Air ...
Best Buy Canada https://www.bestbuy.ca > ... > Countertop Microwaves GE 3-in-1 Countertop Microwave Oven, Complete With Air Fryer, Broiler & Convection Mode, 1.0 cu. ft.1,050 W, Essentials for the Countertop or Dorm, Stainless ... Rating: 4.5 · ‎ 2,370 reviews · ‎ $447.99 · ‎ In stock
3/15/2024 8:00:45 PM • GE Microwave... • Answered on Mar 15, 2024
Can you just repair GE door switch
No Microwave Oven are just too dangerous. The switches and interlocks have to be correctly aligned for safety. Plus the inside has heart stopping voltage waiting to jump to anyone with a half inch away! https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
2/11/2024 9:44:06 PM • GE Microwave... • Answered on Feb 11, 2024
Burn mark on plastic film of microwave door, can I patch with peel and stick plastic? GE MODEL JVM3670SK06
I would not risk it. Your better finding out why there is a burn mark there. The plastic film with the burn mark will be a specific one for microwave ovens. Basic peel and stick plastics could be the wrong type and it could also melt when the microwave gets hot.
12/12/2023 3:37:42 PM • GE Microwave... • Answered on Dec 12, 2023
GE Microwave Model JVM1752SP2SS shuts off after use. Has to be re-booted.
That issue sounds like it it likely to be the control board, or maybe a bad connection to it or a dry joint. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
9/28/2023 2:06:52 AM • GE Microwave... • Answered on Sep 28, 2023
GE JVM1750DM Microwave Oven Logo
19 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
ge microwave model jvm1750dm everything
  • Microwave Ovens
