20 Most Recent
D-Link Platinum RangeBooster N DWA-642 (DWA642) Pre-802.11n Wireless Adapter Questions & Answers
Hello - I have a Dlink DWA642 adapter, and I can
I have the same problem. Thier is is a new driver on the d-link site, also d-link says to use xp's wireless manager, NOT the d-link utility. I haven't had a chance to try this but its a place to start.
I'm running XP Pro. Trying to install
you should check the compatibility of the drivers you are installing with your windows xp, it may be designed for vista or 7, then If it is already compatible, try to plug the card first and then run the setup.
Can't get to internet anymore
Try to remove the preferred networks on your Presario then try connecting again. If you have wireless security enabled on your router, you have to enter that. Make sure that the settings on your router is the same as your wireless adapter so that they can synchronize.
If you have difficulty with that, just ask me and I'll answer as soon as I can.
Strange Internet Problem
Ok this sounds like a perplexing problem indeed... as a work around for now, I suggest that you download and install Firefox... www.firefox.com also get Opera www.opera.com Download these two alternate "Browsers" and install them ... I often find that when one browser will not work, often one of the "Others" will. You may actually find you prefer either or both of these over Internet Explorer 7 (IE7)
It is possible that you may have a virus or malware... ensure you thoroughly check your system.
Also if you haven't got IE7, please upgrade that too.
Also in IE7 reset it to it's default settings, look at the web site below..
support.microsoft.com/default.aspx/kb/936213
support.microsoft.com/kb/923737
I forget it my router password
as funny as it seems, most routers have their default password on the bottom or back of the unit. after you load or configure your router the first time you can sometimes change the password.
5/17/2014 9:52:32 AM •
D-Link...
Answered
on May 17, 2014
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
