20 Most Recent
Blaupunkt Bahamas MP46 CD Player Questions & Answers
Thanks for the response, but this didnt work. Any
Bose systems were not created with aftermarket head units in mind. Normally people perform a Bose-ectomy on those systems, removing ALL Bose components meaning Speakers too. Personally I prefer Pioneer, JBL, or Alpine speakers.
10/18/2017 10:42:42 AM •
Blaupunkt...
Answered
on Oct 18, 2017
I have a balupunkt bahamas mp46 car cd stereo. i
You need to pull the unit out of the dash and pop the top and manually release the disc. If you don't have the keys for the side tabs (if it's not Iso-mounted) check a local car audio shop. They generally can be very helpful. Hope this helps. If your not sure how, post a comment with the make and model car and I can help you further.
4/17/2011 12:50:16 PM •
Blaupunkt...
Answered
on Apr 17, 2011
The volume is too loud......#1 is too loud to hold
Typically the left or right knob should adjust the volume by turning it counter-clockwise. However, some companies need to make this a bit more advanced or difficult. If this is the case, you can try pressing the audio button on the device. If it provides you with any options on the screen, search for anything which indicates changing the volume control. (It may also be under Menu)
Once you do that you should be able to turn the sound down with either the knob on the left or the arrows on the right.
2/21/2011 4:20:31 AM •
Blaupunkt...
Answered
on Feb 21, 2011
In my cedia bahmas mp46
Hello if you still want to solve this, This rquires removing the front panel. Thee are 2 screws inside the coin holder underneath the music panel. you wil be able to see them only if you bend down and see it. Remove them and the front centre panel will come out. then the screws that hold the music player will be visible. The you can remove them and slide th music unit out to fix your pod cable.
11/18/2010 3:26:27 AM •
Blaupunkt...
Answered
on Nov 18, 2010
Harness available for hooking up blaupunkt bahamas
Hi, look for any RCA connectors on the wiring harness or rear of radio - these are the line output connectors - If there are no such connectors then your radio has no support.
Most amps will support hi level input but your sound quality may suffer a little bit because of the extra noise introduced by the stereo amp.
5/5/2010 2:11:02 PM •
Blaupunkt...
Answered
on May 05, 2010
Cant adjust sub out and midrange like i used too.
Hello chev_454,
You can adjust the sound settings for bass, middle, treble, and sub out separately for each source, tuner, CD, AUX, etc. The adjustment procedure is on page 26 of the owners manual. If you do not have a manual, you can download a PDF copy here at
Crutchfield. They show the Bahamas as a discontinued m,odel but the manual is still in their database.
Hope this helps.
6/2/2009 1:15:41 PM •
Blaupunkt...
Answered
on Jun 02, 2009
Hi thereI have a holden barina 2004 with a Blaupunkt 2020 radio.
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code.
You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
