Panasonic PT-56DLX25 56 in. HDTV Television
Problems with Panasonic PT-56DLX25 56 in. HDTV Television?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Panasonic PT-56DLX25 56 in. HDTV...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Panasonic PT-56DLX25 56 in. HDTV Television RSS Feed
View More Results for Panasonic PT-56DLX25 56 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Panasonic PT-56DLX25 56 in. HDTV Television RSS Feed
Answer
I have a hp 7760 photosmart printer that appears to not be turned on
Answer
i cleaned it with glass cleaner and there are black shadows everywhere how can i fix this?
Answer
HP Photosmart 7760 printer - Will not turn on. Unplugged power cord, waited overnight, plugged back... (More)
Answer
replaced bulb in panasonic pt56dlx25 and pic is now blurry??? what d i do?
Answer
is there a way to tell how many hours are used on your lamp. (pt56dlx25)
Find a Manual
Panasonic PT-56DLX25 56 in. HDTV Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Call this number recall or refund
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company... written by jrleopards
I Received Full Refund
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have... written by jrleopards
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for PT-56DLX25 56 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Find an Expert
Meet our 4540 Projection Television Experts
budmrtn
#1: budmrtn
Rank: GuruGuru
Televisions & Videos ExpertExpert
Rating:  87%, 146 votes
Solutions:  727 (722 Votes in the last 30 days)
Experience: 30 Years of professional repair and design.
projdoc
#2: projdoc
Rank: GuruGuru
Rating:  94%, 607 votes
Solutions:  1200 (468 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
dmftrucker
Rank: GuruGuru
Rating:  87%, 412 votes
Solutions:  1582 (454 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Nomodo4u
#4: Nomodo4u
Rank: GuruGuru
Rating:  90%, 257 votes
Solutions:  480 (415 Votes in the last 30 days)
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
cene765
#5: cene765
Rank: GuruGuru
Rating:  89%, 392 votes
Solutions:  746 (401 Votes in the last 30 days)
Experience: More than 5 years attempt with printers, computers and all office equipment
Chu3505
#6: Chu3505
Rank: GuruGuru
Rating:  85%, 408 votes
Solutions:  1346 (379 Votes in the last 30 days)
Experience: I was an engineer for 20 years.I repair tv all models for 15 years for friend shop,was my hobbies.
justaskjoe
Rank: GuruGuru
Rating:  85%, 2004 votes
Solutions:  3887 (369 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
localwonder
Rank: GuruGuru
Rating:  92%, 2792 votes
Solutions:  4928 (320 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
57 varieties
Rank: GuruGuru
Rating:  88%, 524 votes
Solutions:  1495 (294 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
Azraelsrl
#10: Azraelsrl
Rank: GuruGuru
Rating:  92%, 245 votes
Solutions:  350 (271 Votes in the last 30 days)
Find a Warranty
Specifications for Panasonic PT-56DLX25 56 in. HDTV Television
Key Features
Screen Size
56 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated.
Projector Technology
DLP
Display Resolution
1280 x 720 pixels
Technical Features
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Dimensions
Depth
17.9 in.
Height
37.6 in.
Width
51.7 in.
Weight
86 lb.
Connectors
Rear Input Connectors
S-Video x 2 · Audio (RCA) x 2 · Composite x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Memory Card Slot
SD Card
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote Control
Universal
Illuminated Remote
Illuminated
Audio Features
MTS Stereo
SAP / MTS Stereo
Screen Text
OSD Languages
English · French · Spanish
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 15 Watt
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
