Cuisinart Grind & Brew  DGB-500R, 12-Cup 12-Cup Coffee Maker
Problems with Cuisinart Grind & Brew DGB-500R, 12-Cup 12-Cup...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Cuisinart Grind & Brew DGB-500R, 12-Cup...
Troubleshooting and Support
Solved Problems for Cuisinart Grind & Brew  DGB-500R, 12-Cup 12-Cup Coffee Maker RSS Feed
View More Results for Cuisinart Grind & Brew DGB-500R, 12-Cup 12-Cup Coffee Maker
Questions and Unsolved Support Problems
Unsolved Problems for Cuisinart Grind & Brew  DGB-500R, 12-Cup 12-Cup Coffee Maker RSS Feed
Answer
The coffee maker turns off before it finishes brewing
Answer
I have an older DGB550 with a carafe. The unit shuts off before the water reservoir is empty. It is... (More)
Answer
coffee maker with grinder--sometimes, when percolating, it overflows
Answer
The Cuisart makes great coffee but...the timer that starts it in the morning turns it on then stops... (More)
Answer
I did something a bit stupid ... I unscrewed a small screw underneath the filter tray that held... (More)
Answer
cant get the time set coffee maker makes beeping sound i have a cuisinart grind & brew
Find a Manual
Cuisinart Grind & Brew DGB-500R, 12-Cup 12-Cup Coffee Maker Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Cuisinart Grind & Brew DGB-500R, 12-Cup...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Superautomatic does not make coffee. Wet grounds & pump runs a long...
You have a plugged brew head or bent gate valve. I can help with the brew head but not the gate valve. Remove the brew unit. Holding the handle,... written by bansheracer
Superautomaitc does not make coffee. Dumps wet grounds. Short pump time.
If it pumps for a short time and then dumps the grounds, you either need to reprogram the button. Push and hold the button for the coffee you... written by bansheracer
Superautomatic does not make espresso. Dumps dry grounds
Dosage lever or knob is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent... written by bansheracer
No Steam, No Water? Quick Fix
All of a sudden I had no steam and no water. I could hear the pump chugging and trying hard, but nothing came out of the nozzle. First, check to see... written by very-very
Tips for Keeping your Saeco fully functional.
Here's a few Tips for the countless number of people having problems with the Saeco Line Super Automatics Machines. These are more Suggestions if you... written by EspRoastTech
My coffee is weak.
Basing on personal experience (you can find more on Google probably), solutions are: On percolated (filter) coffee machines: Check water temp, if... written by ginko
saeco
descalcified every 3 month the machine will last longer written by pierre235
Keurig B100 Not Brewing Fix
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a... written by Burnzy
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Cuisinart Grind & Brew DGB-500R, 12-Cup 12-Cup Coffee Maker
Nationwide | 866-240-3413 | Website
When onsite service is not an option you can count on ... Read More
Nationwide | 423-303-3785 | Website
Microwave, blender, mixer parts delivered ove... Read More
Nationwide | 718-584-3449 | Website
Authorized Service center for Saeco, Gaggia, Spi... Read More
Nationwide | | Website
Owner's Manuals and dough kneading paddles for jus... Read More
Ratings for the
Find a Warranty
Specifications for Cuisinart Grind & Brew DGB-500R, 12-Cup 12-Cup Coffee Maker
Key Features
Type
Coffee Maker
Capacity
12 Cup
Operation Source
Electric
Built-in Water Filter
With Built-in Water Filter
Technical Features
Built-in Grinder
With Built-in Grinder
Timer
With Timer
Pause-and-serve
With Pause-and-serve function
Cord Storage
With Cord Storage
Dimensions
Depth
8 in.
Height
15 in.
Width
7.5 in.
Weight
10 oz.
Warranty
Warranty
3 Years
Water Source
Water Tank Size
60 oz.
Cuisinart Contact Information
Main support number1-800-726-0190
Describe your problem:
Top Coffee and... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
