20 Most Recent Amana PTH153B35AE Air Conditioner Questions & Answers
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Amana... | Answered on Feb 03, 2019
sounds like your switch dial is backfit try pull it out and reset it back the right way
Amana... | Answered on Jan 14, 2011
Your question is worded strangely, did you have an electrical fire in the unit? My guess is that you have not kept the filter clean and now you need to take it to a service company for the replacement of the heater's fuseable link.
Amana... | Answered on Oct 09, 2009
check thermostat contacts, possibly not sending signal to pick up
Amana... | Answered on Jun 02, 2009
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Amana... | Answered on Dec 07, 2008
How are you determining that one section.is cold and one warm? If this is in fact the case you have a blockage in the coil or a compressor that is down provided this is a multi compressor unit.
Amana Heating &... | Answered on Feb 06, 2019
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
Amana Heating &... | Answered on Jan 27, 2019
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Amana Heating &... | Answered on Jan 20, 2019
Clean the filter and try it again
Amana Heating &... | Answered on Dec 31, 2018
I would guess two possible problems - dirty thermostat contacts and many appliances are also fitted with a thermal fuse or other type of thermal cutout which might have failed.
Amana Heating &... | Answered on Dec 13, 2018
How much power is the question. Remember, heating coils usually require 240 volts. You likely are only getting 115 due to a faulty limit switch. 115 will carry through to the other side of the switch from the coil side leading you to believe the switch is good. Remove both sides of switch and test continuity.
Amana Heating &... | Answered on Dec 12, 2018
Motor might be bad and shutting down on thermal protection. Is this a direct drive or belt driven ? .if belt driven try adjusting the belt tension or just replaced the motor
Amana Heating &... | Answered on Dec 11, 2018
Amana PTH153B35AE Air Conditioner Logo
9 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
amana ptac
  • Heating & Cooling
