20 Most Recent Amana PTH153B50AE Air Conditioner Questions & Answers
see if unit on maintain if so turn off if not bad temp sensor or board make sure fan on auto
Amana... | Answered on Dec 13, 2017
probably low on freon
Amana... | Answered on Sep 08, 2015
I have the same problem, and I found the manual reset inside the unit. Turn the power off, and unplug the unit. Remove the outer cover of the unit ( inside cover ) , and remove the 2 screws holding the " wire mesh " in the front of the cover. Pull the wire mesh up and out of the way, then carefully pull out the heating element.
On the heating element, where the wires are connected, there is a manual reset button... Push the button in, till it resets...
My reset was on the upper left connection of the wires... just looks like a small push button, but the reset is recessed a bit.
Replace all covers and plug back in.. working fine..
Amana... | Answered on Jan 29, 2015
first check you thermostat settings and make sure that it is on a cooling setting if ok it can be the fuse that sends the power to the outside unit if fuse is ok it can be the capasitor for the compressor if ok you may have to check the compressor for open windings or ground fault so you will have to replace the compressor or the relay which is after the thermostat
Amana... | Answered on May 03, 2010
u have 2 get the whole thing its not separate too risky
Amana... | Answered on Mar 07, 2010
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Amana... | Answered on Oct 20, 2009
check to see if unit has a contactor,they arc and weld together,keeping your unit on
Amana... | Answered on Mar 25, 2009
I would try www.sears.com parts dept...have make and model ready!
Please rate! !this is how we keep this website free
Thanl you!
Amana... | Answered on Dec 13, 2008
most boards have a small 3 or 5 amp fuse on the board it looks just like a car fuse. do not put in wrong size fuse it can allow damage to the board.
Amana... | Answered on Nov 24, 2008
either bad heater element or ignitor
Amana Heating &... | Answered on Feb 15, 2018
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
Amana Heating &... | Answered on Feb 08, 2018
You need to reinstall the software http://rollingskygame.com/run-3
Heating & Cooling Logo
16 questions posted
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
amana pth153b50ae
  • Heating & Cooling
