RCA R56WH76 Television
Problems with RCA R56WH76 Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for RCA R56WH76 Television RSS Feed
Click here to get instant support from our best Experts!
View More Results for RCA R56WH76 Television
Questions and Unsolved Support Problems
Unsolved Problems for RCA R56WH76 Television RSS Feed
Answer
I have an RCA R56WH76 that will not turn on the green power light just flashes.
Answer
R56WH76 convergence is out. At the plug going into the convergence board there is no -56v.
Answer
i have an RCA R56WH76. when i push the power button to turn it on - the green light indicating that... (More)
Answer
rca r56wh76. My Rca tv has lost most of its color and is showing a very green /grainy pic..that... (More)
Answer
I have a 56" RCA projection, model R56WH76 thats 2 yrs old. It will come on and stay on for... (More)
Answer
my sony: KV-36SF7 has no picture but the sounds ok. you can see the on screen display but no picture... (More)
Answer
if you trun it on sometimes it will bring up the picture and works. but after about 2 minutes it... (More)
Find a Manual
RCA R56WH76 Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for RCA R56WH76 Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the RCA R56WH76 Television
0
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the RCA R56WH76 Television
Write a review:
Rate this product:
Would you recommend the R56WH76 Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
RCA Contact Information
Main support number580-634-0151
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
