Akai PT50DL24 Television
Problems with Akai PT50DL24 Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Akai PT50DL24 Television RSS Feed
Click here to get instant support from our best Experts!
View More Results for Akai PT50DL24 Television
Questions and Unsolved Support Problems
Unsolved Problems for Akai PT50DL24 Television RSS Feed
Answer
akai pt50dl14xsms - lamp indicator (green) flashes about 20 times - can hear fan running and looking... (More)
Answer
I have just had a error message come on the TV stating to "Check Fan No 2". It then shut... (More)
Answer
The picture on y tv has become dark. The picture is still there but is not as bright as it should... (More)
Answer
I have an AKAI 50in DLP rear projection HDTV model #PT50DL24X/SMS it is 2 years old and has recently... (More)
Answer
Model: AKAI PT50DL14X/SMS We just bought this used TV, get it home and SURPRISE! It doesn't... (More)
Find a Manual
Akai PT50DL24 Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Akai PT50DL24 Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Akai PT50DL24 Television
0
Owners Recommend
out of 3
Reliability
Ease of use
Value for Money
Rate and Review the Akai PT50DL24 Television
Write a review:
Rate this product:
Would you recommend the PT50DL24 Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Akai Contact Information
Main support number4016584032
Email supportsupport@akaipro.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
